JasonWW
(JasonWW)
October 21, 2019, 10:17am
1223
HI mate, how to enable high settings for the Aux LED? Also, can you help me set my aux to blinkinking mode? The manual did not specifically says how except for 7 clicks on off and 3 clicks on lockout mode. Thank you so much.
With the light off, have you tried 7 fast clicks? I think that should switch the aux lights to the next mode.
Down_South
(Down_South)
October 21, 2019, 11:06am
1224
I have one of the MF01S and the Mini in Silver.
Where the full size is anodized so it looks light silver gray and expensive the Mini is stark aluminium.
It’s like the difference between a satin and high gloss paint.
It’s even more pronounced than the BLF A6 SE non anodized which I like and still carry. The knurling on the A6 is tighter so less shine.
The Mini in silver looks CHEAP and on mine you can see the grinding / buffing marks. Definitely non anodized aluminium.
Looks like crap, works like a dream except the battery voltage reading is .5v too low. fully charged 4.2 v reads 3.7 v.
Charging circuitry works correctly for the 26650 that comes with which measured 5670 mah on my Opus 3100 V2.2, a Samsung 40T and 30Q.
Mine rides in a Ultrafire holster I picked up at Banggood years ago for my BLF X6 SE/Astrolux S2 which is still in the box.
Down_South
(Down_South)
October 21, 2019, 10:30am
1225
Mine came with the AUX LEDs set too dim to see on the low mode. Had to take the top off and adjust the trimmers.
Just gently turn each one to see what it does then return it the original setting.
Once you know what each does adjust them how you want.
I’m sure there are instructions in here somewhere but they can be hard to find.
I prefer to change the settings in lockout mode at first as it’s easier. Once you know how, do the normal mode.
Off - 4 quick clicks for lockout then 3 quick clicks advances to the next mode each time you do it. That sets the AUX LED mode in lockout.
Off - 7 quick clicks in normal mode advances the AUX LED mode each time you do it. That sets the AUX LED mode in normal operation.
JasonWW
(JasonWW)
October 21, 2019, 10:40am
1226
Why do that when you can just switch them to the brighter option with 7 fast clicks?
There are trimmers on the board that are labelled, you need to adjust them with a small screwdriver
Danke, ja super, harr, ist es dann vll Die Eine Lampe? Auf Die ich mein ganzes Leben gewartet habe? Fehlt nur noch ne Throw Led in der Mitte mit Zusatztaster fürn Spot, gibts sowas überhaupt? Schwierig mit dem Reflektor...
Translation:
“It even says it on the board:
‘Low’ for red
‘High’ for green
D1 blue
D2 pink
Unfortunately Astrolux set the trimmer values far too high and the LED resistance too low, it’s hardly possible to set up ‘bright’.”
Down_South:
That makes me glad that silver was unavailable when I ordered mine, so I just chose plain black, same as my MF01s.
Down_South
(Down_South)
October 21, 2019, 11:30am
1228
I’d say “If they can’t see you they can’t shoot you” but then I’d have a different flashlight. Actually . . .
Because I prefer the low mode as it’s plenty bright to find the switch. My way, if for some reason I want the high I can choose it.
Wish the AUX LEDs could be off with just the switch lit. High, low, breathe, off.
Life’s about choices. I like all I can get. It’s why I left the USA years ago.
Little freedom left there when I left and none now so I’m told by almost everyone returning from there.
That’s what I hear every time I go to the local VFW for some beers and talk.
Down_South:
Oh no. It looks like I have to cancel my silver order if possible and just go straight to full copper.
I also have same issue with the voltage indicator. Mine is 0.2V off.
rbpinto
(rbpinto)
October 21, 2019, 11:52am
1230
Down_South:
Thanks for sharing!!! I have been tempted to go for the Mini in silver as I really liked how it looked in the Banggood pictures where it has a darker, richer look. However another picture online showed it to be much a lighter silver which I too thought looked “cheap”. Your confirming this has saved me the disappointment I think you feel. Hope you find someone you can sell/gift yours to and then pick up a better colour. I’m going to finally pull the trigger on the gun metal grey.
patmurris
(patmurris)
October 21, 2019, 1:11pm
1231
Down_South:
This sounds good news to me! I loved the bare al A6… and was very disappointed by the clear ano L6 which looked like a fake silver plastic toy to me.
Yes I did the 7 clicks a number of times but the aux lights remain still.
JasonWW
(JasonWW)
October 21, 2019, 1:51pm
1236
Make sure you are not in muggle mode.
pooptoast
(pooptoast)
October 21, 2019, 7:21pm
1237
Got mine a few days ago and I’m really impressed. I ordered a silver 5000k but asked if they could send me a green one instead and Banggood came through. Very happy that they did, the color looks great. I do sort of wish I’d gone for the 4000k but I have an MF01S in 4000k so I figured I’d try a different temp this time. It’s nice but not as nice as the 4000k; oh well, live and learn.
Dr.Phillip
(Dr.Phillip)
October 21, 2019, 7:39pm
1238
Could I hear opinion of some battery experts on using MF01 Minis with these batteries:
https://s.click.aliexpress.com/e/2DLOuvIs
I have no experience with Liitokalas 26650, I heard that these blue ones are good, but can they pump those 20 Amps this lights can handle in turbo?
KevinZA1988
(KevinZA1988)
October 21, 2019, 7:45pm
1239
Why don’t you just go for this?
Vapcell 26650 battery 5500mah 20A Li-ion battery 3.7v Rechargeable vape cell for smoke E-CIG
https://s.click.aliexpress.com/e/ZGJy6JdbV
Dr.Phillip
(Dr.Phillip)
October 21, 2019, 7:55pm
1240
I have ordered some Shockli IMR 26650 from banggood and those should be the same cells you mentioned just rewrapped (from what I heard). But I have those 2019 Liitokala 26650 I bought for a different flashlight and wonder to what extent I can use them in this one and what I can get from them.
KevinZA1988
(KevinZA1988)
October 21, 2019, 8:02pm
1241
I see… I had good experiences with the Liitokala black 26650 cells. Someone or somewhere on BLF should have some info on this.
Output on turbo woold be lower but should keep up longer. We need some test to really know. The battery would be worn down, capacity lowered, faster but with turbo being so short it might not be too bad.
The black Liitokalla would be an alterntive inbetween them.
The Vapcell look very expencive, it is just for one battery.
