This light doesn’t have any third party drivers available right now. It’s designed to run three LEDs in parallel all at once, so the multicolored board you linked wouldn’t really work.
JC (from JC Customs) is putting boards with secondary emitters in the FW3A. I know he’s been recompiling Anduril to allow control over the secondaries.
Supposedly it’s just a flag that needs to be set in the source code. I haven’t downloaded it myself in order to see how easy it is to read (and compile).
For anyone who may have missed it… there’s really a simple, cheap, and effective switch boot mod for reducing - or in my case eliminating - accidental activation.
Carefully disassemble the tailcap, keeping track of the ‘nubin’ (tiny, tiny plastic cylinder) but removing it. Then filling the cavity in the rubber boot with a thin rubber disc. I used an random o-ring and sliced piece of silicon wire insulation. I’ve found the best results with a flush fill level. I can imagine slicing a pencil eraser with a razor blade would be a simple DIY option for almost anyone willing to attempt the mod. Reversible and nearly free. Quiets the switch a bit too, but YMMV
