Neal's son with "uncle Martin" :D
awwwwwww
I think I remembered a meme
A boy ask his father, “Dad, why my sister named Rose?”
“Because your mother loves roses” say his father.
“Thanks, Dad”
“No problems, Lumens”
:+1: :+1: :+1:
:D
don't tell Neal's wife...
Very cute!
Order sent. It’s been a while that I looked forward to a light as much as this one.
Thank you to all involved in making this happen.
Hi Martin
Thanks,ordered
Regards Xandre
Interested, email sent.
Interested!
Ordered, thanks!I suspect this light will be a big hit. Sould be perfect for my needs.
Ordered, thanks
Sorry so late, but just submitted a request. Is it still good?
Hi Martin, could you still send me a code for 2nd batch?
Do you have any info about approximate lumen specs or current draw of all mods?
Could you confirm the light always starts on moonlight mod (no memory)?
Thanx! Got the code and submitted the order for batch #2.
Afair it has mode memory
since I am not at home I cannot measure every mode etc...
codes are sent to all requests asap
still not easy here in China ;)
will be better Monday when I am back
Good to know. I just purchased three units. If you can confirm turbo is in the mode sequence or at least if turbo can be memorized, I’ll purchase another 3 or more more.
How’s does the SBT90 Gen2 compare to Osram leds, such as white 1mm, 2mm etc?
SBT90.2 has wayyy more lumens, wayyy more amps. Not sure head-to-head on throw in similar lights, but I would imagine the 1mm/2mm's are more of a pencil beam simply because of the higher lumens of the SBT90.2.
I try to find out
Edit: Neal said yes
