Why designers choose “hold for off, click to cycle modes” instead of the reverse is… puzzling.
It’s like people without legs designed a bicycle for people without hands.
Technically it works, but it’s awkward and non-intuitive.
I think it might be to prevent returns from users used to lights having a single mode - not that it justifies it, just my theory.
I prefer clicking to change modes, unless in ramping mode - then I control how fast the modes change and always stop on the desired mode.
With hold to change modes, as on my Rofis R1 and R2, I sometimes have to go through the cycle a couple times to stop on the correct mode.
I do like click for off, but you can’t have click for off and click to change modes in the same single switch light.
Oh boy. I’m excited about this light.
Please tell me this is roughly the same reflector as the WK30.
I call that the “Acme Clip”
I haven’t used any Rofis lights but no light with hold-for-cycle I’ve used has been anywhere close to fast enough to overshoot what I want. I do like how fast you can cycle them with rapid taps on tail-switch lights and the dual-switch TO50R I have though.
My thoughts…
The Good:
- Great LED choice
- USB-C charging? Awesome
- Shortcut to turbo (will this work from Off?)
- Ramping option with single click on/off
- Below $30 including a battery
The Bad:
- No mention of Eco/moonlight shortcut (hold from Off would be good)
- Hold-for-off in the stepped mode
- Timed stepdown instead of temperature regulation: given the price point, I can forgive this. But it does make me a bit sad
looks great, looking forward to it .
I’d rather see the pocket clip captured by the tail cap so it CAN’T pop off.
Something other than black would be great, but I’m definitely interested in this.
Definitely needs to be clarified if the light will have hold for moonlight/low also. The standard for any e-switch light should be: hold for lowest mode, double click for highest mode, single click for memory.
That tends to be my preferred approach.
I’ll definitely have to check this one out!
nice stuff
Good idea. If the FC11 becomes highly demanded, this could definitely be an option in the future, e.g. military tan / "dark earth".
I will soon receive a prototype sample that I can test. So far, I was told that moonlight is not available from OFF. The good news is that Wurkkos and Sofirn are always open-minded to suggestions, so I will collate all your input together with the impressions I will get from the sample and report them back to the manufacturer. They will thoroughly check each single improvement for cost effectiveness and feasibility.
Does anyone actually use electronic lockouts in the real world? I ALWAYS use a tail cap lockout. I suspect the lack of hold for moonlight is because they’re using the “hold” UI option for the mode change which, IMHO, is dumb. I’d much rather see the quad click used for mode change and “hold” for moonlight.
Either way, this and the YLP Unicorn are very interesting lights to me as EDC and gift lights. Sadly, I probably won’t give away any Unicorns since it doesn’t have built in charging.
I use electronic lockout all the time when I’m pocket carrying an eswitch light. All my eswitch lights are Andruil so it’s easier for me to do 4 clicks with one hand than to twist the tailcap. I also have momentary when electronically locked out where a mechanically locked out light has to be “unlocked” to get any light.
Just my .02
“press and hold for 0.5 second to turn off”
That killed it for me
Update: Manuals available for download in English and German language, see post #2.
