I have some NW and CW emitters which are pretty decent, those “angery blue” tints are just annoying (though I can tolerate them in a 5mm in certain applications).
That said I just don’t see any reason to tolerate low cri anymore. You have the sst-20 which offers high current and output in a small size, LH351d and even the xpl hi is offered in 80+ cri flavors. I guess if you are just trying to build a lumens monster that’s one thing but for real world use why wouldn’t you want a high cri led? I get with the 219 leds you were sacrificing some max output but with newer options you aren’t, really. At least nothing that would be missed.
For example I just reflowed a 4000k sst20 into my lumintop worm. It’s still every bit as bright as it was with the xpg but now in a beautifully neutral tint with great color rendition. Still the same excellent beam shape, too!
The SST-20 is quite low output for it’s amperage. The XP-G2 blows it away. It’s close to the 219c output. It’s just a small die, so output is not so great.
I thought this was quite well known. Here is a direct Djozz comparison from this thread. This is a 3,000K, maybe this particular version has lower output? The G2 in this test is a 2B tint so around 5700K. Maybe it is around CRI 70? That might explain some of the big gap.
Maukka’s test above shows higher output, but I can’t find any tests from him on the XP-G2 or 3 for a comparison.
The general characteristics I remember from the SST-20 is it’s cheap, looks good, throws well due to it’s small die size, but output is lower and it runs hotter.
The 3000K and 4000K are high-CRI only and therefore significantly less efficient. 5000 and 6500K are 70-CRI only and still compete with much larger die emitters in output/efficiency.
On Emisar lights for example the max output of the former is listed at ~3000lm, and 4200+ lm for the latter.
I think all the SST-20 tests I’ve seen were a while ago and they were all high CRI because that is what people seemed interested in. Like with FW3A for instance, the SST-20 were only for the WW tints then they switched to XPL-HI for NW and CW. You could see the big difference in output and heat. Maybe I have not given the cooler tinted SST-20 enough research. I haven’t fully read Maukka’s 6500K test. Maybe they are not as bad as I thought (efficiency wise).
Yeah for sheer output while having very high illuminance the cooler SST-20s are pretty solid. Only issue is how green the beam is compared to other options like X-PL HI.
Who’s numbers are these?
It’s not an apples to apples comparison due the dome difference, but still pretty close. Especially considering the XPL has a 2mm2 die and the SST-20 is closer to 1.20-1.25mm2.
IDK how it’s “not apples to apples”. The X-PL HI is dedomed but the effective die size of the SST-20 is still smaller, that’s why its throwier. The point was that it’s comparable to emitters with a larger physical die in output and efficiency (but unfortunately has a pretty gross beam in comparison).
Ooof, that TA chart is from Jan 2017. I think TA’s integrating sphere was reading a bit too high back then. We may need to adjust those results down a bit. When we do that the 2 LEDs are actually pretty close to each other even with different die sizes.
Yes and no.
With optics, XP-L HI and SST-20 have quite comparable beam widths; the latter being a bit narrower despite having a dome.
For most uses where one would consider XP-L HI, SST-20 is worth thinking about as well.
BTW I wish there were intermediate CRI variants of SST-20. And a factory domeless option.
CRI95 is indeed inefficient, the price one has to pay for pushing CRI this high is very significant while CRI80-90 is not so bad in other modern LEDs (about 5-10% for 80, 15-20% for 90). CRI95 in SST-20 costs very roughly 45% output. :person_facepalming:
Looking at HaikeLite's new HT70 I wonder if Sofirn could consider upgrading their SP33 V2 (boost-driven 6V XHP50.2) with the new Luminus SST-70 including SMO reflector. According to Djozz' test it should output around 3.500lm at 5A (that's about the max. current SP33 V2 used). They could call it "SP33 V3 Pro".
SP33 V3 = 3V XHP50.2, FET driver, OP reflector, proprietary Sofirn UI
SP33 V3 Pro = 6V SST-70, boost driver, SMO reflector, Andúril UI, desert tan color
I really hope the majority is not always looking for more and more lumens, only. There are so many advantages to be expected such as a more stable runtime (even on turbo), less tintshift compared to the 3V XHP50.2, better throw and - most important - less heat generation at 6V. You need 10A at 3V what you can achieve with 5A at 6V.
Sofirn is currently working on a new corporate design, including a new slogan they may put on their cardboard boxes. The slogan should ideally reflect following content: high quality, reliable products, great customer service and affordable prices. Your input will be deeply appreciated. :THUMBS-UP:
I disagree. A 6V XHP50.2 runs much more efficient at 6V 5A than a 3V XHP50.2 at 3V 10A. Regarding the lumens output I was referring to Djozz' diagram (3.500lm @5A), that's why I expected the overall output to increase. Again, what good is a 3.500lm FET light that will step down very quickly due to excess heat and that can only reach this peak value once and only with a fully charged battery while you can get a bit lower but more or less constant regulated output with better components (boost driver, higher voltage, better emitter)? My impression about SP33 is that many people were asking for the SMO reflector to get more throw. This would be a great opportunity to have both better throw and better tint without defining everything new again.
