This one looks nice, however I can’t see if this is a “true” scandi grind, it seems a bit of a hollow-scandi grind. Maybe if someone has this knife already, could confirm?
I have more than a few of THESE Great little mini knife. Built like a tank. I take the clip off, it just rides in my britches. The damn clips is so tight you can barely get it to clip on your pocket then, good luck getting it off when you want to. Not for heavy duty use. Non locking knife that small is for me super light duty only.
You’re welcome!
These mini friction folders were released at least 2 years ago on Ali . Canku is just a newcomer rebrander.
You can find them on my blog here
You should check this store out too. They have plenty of interesting stuffs.
This is my freshly arrived FZIZUO kitchen knife from them with VG10 core damascus blade. The feel of quality, fit & finish are superb so I’m quite impressed so far.
Other CH knives tested by Luv Them Knives have been the advertised steel. Hardness seems to vary. Some were above the advertised hardness and some were below.
This knife has a curious blend of features. It’s a folding knife with a flipper tab. It’s also a cleaver with a hole for hanging. It isn’t just any hole either. That hole is meant to hang securely on a nail.
You can easily tell if its real D2 or not. Since its not a stainless steel you will easily get light rust stains on the blade. All my no-name titanium D2 knifes are fake but not my Ganzo and Sanrenmu.
