Agro
(Agro)
October 25, 2019, 5:33am
139
Wonder what the flux bin is. Here is the chart from the SBT90.2 datasheet below. I’m trying to order 3 pieces of just the LED mounted on a 20mm MCPCB but all they had was flux bins RB and SA, so I’m ordering the SA bins, but there 5 higher bins listed:
Thanks a lot for that datasheet!
Some notes:
this LED has seriously low Vf. About 3.35V at 20A.
~100 lm/W at 9A (the binning current), but cold binned.
About 5300 lm at 22.5A compared to CFT-90 4800 lm (sourced from CFT-90 datasheet, not from test). And it has lower Vf, so it’s clearly more efficient.
This may not scale to extreme currents like CFT-90 but nevertheless thanks to not-so-terrible efficiency it may be the new king of big throwers. :student:
also interested for 2nd batch
M4D_M4X
(M4D M4X)
October 25, 2019, 9:26am
142
please send me a PM - easier for me to answer asap
atsteele
(atsteele)
October 25, 2019, 8:24pm
143
Anyone have any info in the rear clicky specs? Dimensions etc? Looking to put in a reverse clicky
Th558
(Th558)
October 25, 2019, 8:36pm
144
Someone correct me if I’m wrong but I think it already has a reserve clicky.
atsteele
(atsteele)
October 25, 2019, 9:15pm
145
Sorry. Want a forward CLICKY.
Tom_E
(Tom E)
October 25, 2019, 9:16pm
146
Listing says: Swtich: 20mm,10A reverse switch
typos and all...
Ohhh - fwd switch.
Th558
(Th558)
October 25, 2019, 9:36pm
147
10A switch with a 20A LED. Something isn’t right here. Maybe they used a different switch for this one.
djozz
(djozz)
October 25, 2019, 10:07pm
148
The little Onten 1288 switch is rated at 1A (30V) and is used in flashlights up to 15A sometimes. Specs are not as simple as they sound.
atsteele
(atsteele)
October 25, 2019, 10:42pm
149
So what should I buy for this host ?
KawiBoy1428
(KawiBoy1428)
October 25, 2019, 11:35pm
150
I use these KAN-9 10amp FWD click switches 20-30amps with 18awg bypass…no problem…
. Page Not Found - Aliexpress.com
blueb8llz
(blueb8llz)
October 26, 2019, 4:43am
151
Would have been cool if they gave us option to choose forward clicky. Would be cool if it was a standard thing to offer both from all companies.
makapuu
(makapuu)
November 3, 2019, 3:04pm
152
Hi Martin. Reports are starting to come in saying that the memory is intermittent. Also mode switching, as well as the button feel/press. Can you check with Neal on that.
That is a huge factor on whether I would want the light, because I would like the light to start out in turbo.
According to some feedback on TLF the positive terminal of unprotected 21700 batteries like Samsung 40T will be crushed. :-(
mortuus
(mortuus)
November 3, 2019, 9:15am
154
dissapointing to hear since thats a standard very good quality highdrain battery to use in many lights :person_facepalming:
Tally-ho
(Tally-ho)
November 3, 2019, 10:04am
155
I would have like to order it but a few things need to be fixed before I consider it. Sorry Martin, I put down my email for the GB, but not this time.
M4D_M4X
(M4D M4X)
November 3, 2019, 12:39pm
156
I hope my sample arrives soon to check those points
Xenovora
(Xenovora)
November 3, 2019, 1:37pm
157
Does that include the Shockli 5500 battery that was marketed along with the light? Hope not… I bought two of those batteries and 2 lights…
Th558
(Th558)
November 3, 2019, 1:41pm
158
Nope. Thats a 26650 so it’s fine.
