Emisar D3AA is available now
What does everyone think of the xpl hi v3 3a 5000k?
Everyone includes me :innocent:
Slightly too cold tint, light quality is very dull and boring, compared to any higher CRI led from other manufacturers that take illumination quality more seriously. Ok for occasionally lighting up stuff in the dark, unbearable for EDC.
If you asked that question three years ago I really would have liked the led, but so much has happened in led quality the past years (but not at Cree) that it is not so anymore.
I went the same way. True, good old XP-L HI has low CRI, but as I was advised by TK, they sustein the highest output due to least heat production. Bingo for me since in this case I pay much attention to long-term output.
I’m more CRI demanding when it comes to headlights…
Ordered a D4V2 w/ XP-L HI V3 in Sand + the clip and magnetic tailcap on the 20th, looks like it left China today.
Just ordered the D2V2 Ti/Cu. :smiley:
I also just ordered a D4 V2 TI CU and 18350 tube.
I have the V1 TI CU and truly is a thing of beauty.
D4 V2 TI CU SST20 5000k option sold out??
Yes, the SST-20 5000K LED is currently out of stock, and we are not sure when it will be available again.
I also ordered D4V2 Ti only at Nichia’s , I will solder 351D 2x4000K and 2x5000K . It will be a miracle , not a flashlight !!!
Would it be possible to order the lighted switch and the white switch cover separately to use it with other Emisars?
LOL...i’m still using H4 incan bulbs hahahaha
The switch PCB from the D4v2 Ti+Cu does not fit into the D4v2 Aluminum.
Thank you, that’s good to know. Would be too nice if it worked!
Can someone show me how looks the D4 Ti v1 after time. Thanks
Is the opening in the D4v2 Aluminum too small?
If so, it might still fit with a little dremeling or filing.
Will you offer it with warm white high CRI LEDs under the button and with adjustable brightness levels let’s say up to 5-10 Lumens to use as reading light or as all night long room light!! It would be awesome!!
if you do it i I will buy up to 5 lights
Also why you don’t offer more high CRI LEDs options??
Red leds under the button is awesome too!!
nice one bro
Guys, all of us who placed prder as soon as iz became available (V2), are we getting raised or flush button switch?
That option is only now available....
I ordered mine a couple days ago when the option was available on the website.
Personally, I chose the flush-switch. The raised switch offers additional protection against pocket activation. But with Anduril, it’s less important than with the D4v1’s rampingIOS. Anduril has protections to prevent pocket burning.
I have a D4v2 with the raised switch ring. It works, but the upper edge of the ring is a bit sharp. I much prefer my home made raised ring constructed from a filed down nickel-plated brass finishing washer, which has a comfortable rounded feel at all angles.
That’s what i was thinking to make my own switch ring!
