LED-ENGINE-UV365nm shuts-itself off after ~40seconds
Isn’t mentioned anywhere. But my experience with their CS dept. is very good. If they know, they will tell.
Believe it or not, I bought two of them when they were first released and were single-mode only.
Not sure, but I think they are now 2-mode....
@aL1, have you thought of asking them what kind of MCPCB, what kind of LED, and what kind of current they are running the LED at?
Never heard you mention the type of battery(s) you’re using. I have a few lights that if the battery discharges down to 3v they will just shut off.
^ That is a possibility.
First off I would take the Drop In out of the host and wire it directly to make sure it’s the Drop In itself and go from there—I’ve had ground issues athe the head and also around the switch
Should be the first thing to check, IMO. Battery and dirty contacts
They were not very helpful with any info.
I used an OPUS BT-3100 to test the batts....both fully charged....
As it turns-out, two new batteries seem to have resolved the issue, time will tell.
BTW, the batts that appear to be the cause were (almost never used 16340 KeepPower 700mAh Protected Button Tops), replacing them with CR123's looks like the charm.
Did that too-
See Post #23 above-below??, both batts were fully charged and the contacts cleaned.
Good deal. Sounded like batteries to me. I never use protected cells, especially with a device that has LVP like your’s apparently does. Those KP’s must have been voltage sagging like crazy. Vapcell has nice 16340s. I use a pair of them in a high powered laser
Maybe the protection circuit on one of the batteries was cutting off. You can strip the protection circuits off those cells
They could have high internal resistance in which they want produce much current without the voltage sagging alot. Are they old cells or fairly new.
I have had lights that wouldn’t run but maybe 30 or 40 seconds because the battery voltage under the load dropped below low voltage protection.
Changed to higher current batteries and problem solved. The batteries I ran into the problem with was 16340 sized. I bought and tested several different brands. The best for high current that I have tested is the Vapcell 16340 800mah.
I strongly disagree.
From builders and sellers point of view, there is no excuse to treat customer who paid a great deal of $ for your product in such a manner, even less excuse is having a bad day.
If you ever built a product in batches or 10-20+pcs of identical or very similar product (and I believe you did) then you exactly know what are the week spots of that product and what situations can happen during use of the product.
When someone calls me and say “hey this happened” I know exactly what he did that lead to failure.
Also as a builder that wants to sale his products you have to take in consideration that not everyone that will use your product is familiar with it, or that they will read manual or that they will care about the product at all, you have to predict as best you can all the things that may affect your product in negative way.
Someone may insert battery reversed, ok, you can either make reverse polarity protection or not but you know what will burn if this situation happens, or someone may put 2 small batteries because hey, years before they had flashlight that used 2 x CR123 batteries so they thought it will shine more if they put 2 batteries insteda of 1 18650 and the working voltage of the product is up to 4.5V. Either you will make product more expensive by designing it to be able to handle this situation or something will burn and you will know what was done to it.
Either way, buyer offered to pay just to diagnose the problem and give their opinion, maybe it is fixable, maybe its not, it is your product and you know that even without having it in your hands.
If the product is potted and there is no way to get to vital components without causing irreversible destruction then that’s what you need to explain to customer, and not act like customer is stupid and does not understand what 30-day warranty means.
When someone calls me and says “I have Acebeam…” with this or that problem, first thing I explain is that Acebeam is heavily using glue to prevent opening their lights, I can try to open it but that will probably cause some damage to the product (I always try to prevent this but I make sure that customer knows it may happen) on top of that if I open it and find the problem, it may still not be fixale (or I will not be able to fix it because I do not know everithing, im not EE).
After customer knows all this it is his choice if he will accept my terms or just keep the faulty product as a paper weight.
All in all, if you don’t want and dont know to deal with customers with problems (because sooner or later you will have unhappy customer) than get a job that does not involve interaction with people.
@Sirius9, that was why I mentioned a builders point of view, which is not what you should communicate as a seller.
When I bought my Ledengine uv 3mode dropin I was told to “only use cr123’s”
18650 works ok but I don’t want to mess it up.
Does anyone here know why they don’t want me to use 18650’s?
If an 18650 fits it probably won’t have enough voltage to get full output, and 2x16340 voltage may be too high at 8.4v.
Thanks. I know not to use 16340’s but why 2 cr123 vs. 1 18650 where cr123’s are fine but 1 18650 is bad.
Nothing to do with the physical size of the battery. CR123’s are 3 volts each, x 2 = 6 volts. A single 18650 is only 4.2 volts fully charged.
Ok man thanks. That’s what I needed to hear.
