Astrolux C8 driver replacement options
6 posts / 0 new
2muchgain
Last seen: 11 months 4 days ago
My Astrolux C8 is stuck in one mode . I`ve tried switches from 2 Convoy C8s with no difference .The Astrolux switch works fine in the Convoys .
Multimeter reading is 2A .
I`d like something that has the turbo setting .
Lexel
Lexel's picture
You can buy one of my 17mm drivers with Bistro HD OTSM
2muchgain
I don`t know whats happened but the Astrolux C8 is now working with a Convoy tailcap and switch .
The problem now is even on turbo it`s the same brightness as a Convoy C8 clear .
Where can I find an Astrolux switch with a double spring or would a spring bypass on a Convoy switch give me the extra power on turbo mode ?
Lexel
Lexel's picture
switch spring bypass is always the preferred method, better than double springs
2muchgain
Found one .
So is it a combination of FET driver and double spring giving the turbo boost or just the Fet , and is the regular spring restricting the power when using the Convoy switch ?
Lexel
Lexel's picture
each resistance eliminated gives more current
