Nope, not opening no matter what direction trying. Had it in a vice and turned with full force until the needlenose pliers started to slip…
Too bad, hate to lose a light over a $1 worth of parts.
Interested in this discussion. I used to use my Fenix L2Tv2 a LOT but not so much anymore. The Lumintops are out for me because I abhor last mode memory. The Jaxman M2, which I own, is a great general purpose 2AA light but as mentioned is not pocket friendly.
I am looking at some the Eagtac options right now, but the new Quark looks really nice. Just no budget for that expensive of a 2AA light for me…
Nothing on the TK4A? Nice light that eats 4 AAs at a time…
I got a Nitecore MT20a. It’s very similar, a hint girthier, then my Fenix LD20. It’s right on the budget, similar beam, maybe a hint throwier. It has a rear clicky but also a side switch and an integrated red LED for night stuff.
If you don’t want the red LED the nitecore MT2a is a little leaner.
Also, a great, budget, not to tactical 2xAA light is the Lumintop Tool25, which is super simple and probably brighter and smaller than both, but more flood than both as well.
Now looked some reviews and this also looks really good… Anywhere this can be bought ? Couldn’t really found any store with google with it in-stock. I just don’t know the places where to look :person_facepalming:
Haven’t looked offhand. Tried GB abd BG, no joy.
Okay, so the Sofirn SF11, https://www.amazon.com/dp/B07RHT55W1 ? Dunno if there’s an amazon.fi or anything…
if you can’t find the 4xaa thorfire maybe try the 4xaa nitecore EA45S
It is at banggood at 32€
I have had the sofirn sf11 for several months and find it to be excellent. I use it for walking and the double click to strobe is excellent for crossing streets. I’ve had vehicles stop at crosswalks where normally they blow through. It has a decent throw and also a good spill and lots of light.
The “moonlight” is a bit bright for preserving night vision inside the house but I don’t use it for that anyway.
I’m using rechargeable 2450 mah batteries in it.
John.
How about regulation? Does it produce constant output during all the runtime? I mean… The circuitry does pull more amps as the voltage goes down to maintain constant brightness??
Any review with graphics showing that?
Thanks
Had a SF11, seemed like a nice light until the switch died within the first month. Not a fan of the beer can form but I can see how some would be.
I got a bunch of multi-AA lights just to burn down in bulk the excavated relics I found in fossilised 40pax of AAs and the like.
Rayovac and (black) Rat Shack brands, never leaked. Enerleakers and/or Duraleaks would’ve been salt-blocks by then.
SF11
I use 4 Eneloops. Really makes a lotta light.
samgalax:
I am not equipped to do a test of the regulation. I seldom use the high mode - usually the lowest (non moon) mode and it lasts a long time on a set of batteries. I have noticed that using it in high mode does tend to deplete the batteries fairly quickly but can’t give you any measured times on that. The switch glows green if the batteries are “fresh” and then orange/red if they are low. Being a “pop can” light it is a bit harder to hang onto however I use a lanyard and that helps a lot.
John.
Thanks a lot!
Blew my budget and got fenix ld42 locally, seems just fine. Plastic batterybody doesn’t bother me, seems to be something like polycarbonate so should stand up to my easy usage. Also it’s getting eblow zero here 24/7 in winter so no heat issues I think. It’s throwy but still has decent spill, only hope is in future they make more neutral white options. Thanks for suggestions though, may buy some of the suggested light as second light or gift!
Just some comment on the ZanFlare F2 vs Lumintop Tool25, since although both use 2xAA, the Tool25 has a smaller head (more floody) while the ZanFlare F2 has a slightly bigger head diameter.
The ZanFlare F2 may only be "200" lumens but is the more "throwy" light, whereas the Tool25 has a more 'balanced' (not too throwy) beam pattern.
(in the video, flashlight is around 18 meters or 60 feet away from the "wall")
The Zanaflare is a very decent light, especially at that price. Any ideas on options without LMM?
