[♛ FreemeGB] Eagle Eye Mezzol X8R XHP70.2 XHP35 21700 Rechargeable Flashlight Group Buy >>> from $22.99
:smiley: :+1:
Also interested in the x8r-L. Can you please send the code? Thanks!
Interested
sent
Hm… Interested in A and L models. Thanks.
Has anyone received their lights yet?
No code received.
I did leave a pm just now.
freeme
I will receive in a few days. I will try to find time for a micro review.
interested.
In my opinion, it turned out to be a suitable candidate for EDC, quite compact, in the hand it is very convenient.
Reflectors:
The set of brightness modes in my optimal.
The voltage at the end of the charge is 4.18v.
Temperature behavior. Air 23 ° C, no cooling.
1200Lm - 49 ° C after 10 minutes and 56 ° C after 20 minutes.
There is thermal control, operation in the region of 62 ° C, brightness decreases smoothly.
How it shines (I apologize for the white auto balance):
X8R-L (NW) and Sofirn SP33 XHP50 6000K
X8R-L + Sofirn SP33 XHP50 + Convoy S2 + SST40 5000K
PWM
Interested xhp70.2 code please.
interested
For Mezzol X8R users. Check tail cap spring. I found it to be poorly polished and highly scratches the battery.
A quick fix will be using a pair of pliers to put the tip of the tip inward (0.5mm?) or a file to smoothen the tip.
with this different small head the flashlight will be sure shorther right?
a little bit
any runtimes? for xhp70……seems a bit heavy and big for classical edc…but….the output…
Code is active please?
