Yes, the SST-20 5000K LED is currently out of stock, and we are not sure when it will be available again.
I also ordered D4V2 Ti only at Nichia’s , I will solder 351D 2x4000K and 2x5000K . It will be a miracle , not a flashlight !!!
Would it be possible to order the lighted switch and the white switch cover separately to use it with other Emisars?
LOL...i’m still using H4 incan bulbs hahahaha
The switch PCB from the D4v2 Ti+Cu does not fit into the D4v2 Aluminum.
Thank you, that’s good to know. Would be too nice if it worked!
Can someone show me how looks the D4 Ti v1 after time. Thanks
Skylight:Would it be possible to order the lighted switch and the white switch cover separately to use it with other Emisars?
Is the opening in the D4v2 Aluminum too small?
If so, it might still fit with a little dremeling or filing.
Will you offer it with warm white high CRI LEDs under the button and with adjustable brightness levels let’s say up to 5-10 Lumens to use as reading light or as all night long room light!! It would be awesome!!
if you do it i I will buy up to 5 lights
Also why you don’t offer more high CRI LEDs options??
Red leds under the button is awesome too!!
nice one bro
Guys, all of us who placed prder as soon as iz became available (V2), are we getting raised or flush button switch?
That option is only now available....
That option is only now available….
I ordered mine a couple days ago when the option was available on the website.
Personally, I chose the flush-switch. The raised switch offers additional protection against pocket activation. But with Anduril, it’s less important than with the D4v1’s rampingIOS. Anduril has protections to prevent pocket burning.
I have a D4v2 with the raised switch ring. It works, but the upper edge of the ring is a bit sharp. I much prefer my home made raised ring constructed from a filed down nickel-plated brass finishing washer, which has a comfortable rounded feel at all angles.
That’s what i was thinking to make my own switch ring!
Is the switch bezel screwed or press fit?
I recently contacted Hank about the raised retaining switch option and he added it within the hour. Got mine ordered!
Press fit, but still replaceable if you’re careful!
It seems like every model is getting a V2. Any word on if there will be a D1 V2?
Haven’t heard about the D1 but there will supposedly be a D1SV2:
In the german TLF somebody quoted Hank: “… we do have the plan for the D1SV2, with truely constant current, bigger head, USB-C charger, 21700 battery, should be 50kcd+ with the Osram LED. There will be XHP35HI options as well.” And futher on he said it should be available in the next 1-2 month. Sounds extremly exciting! But bigger head+osram LED = 50kcd? Maybe a mistake? Should be much more, shouldnt it? Cheers, Michael
D1SV2 is definitely in my wishlist iffn it completes my green collection!!!
Mine shipped this morning. Thank you Hank!
Ordered 2 pieces of D4v2 from Hank less than 24 hours ago and they are already shipped with tracking info. That was quick.
