I just got the E07 w/ the SST-20 2700K. It has a really pleasant rosy tint. The SST-20 2700K seems a bit rosier than the 3000K. I ordered it with red Aux light but it came with purple Aux The SST-20 2700K w/ Red Aux lights would make for a perfect bedside light due to it’s very low blue wavelength emittance so it won’t suppress melatonin as much as other lights. Also red light is known to induce sleep among other benefits.
I noticed an issue with the translucent o-ring between the battery tube and head seems to keep squeezing out when tightening the head and sometimes it prevents electrical contact. I think a thinner O-ring would fix the problem.
Here are test results using fresh off the charger Samsung 40T.
I’m surprised this time the UCL lens hardly lowered the DUV. I saw much larger improvements from switching to UCL lens in the several older E07 that I tested. Maybe Fireflies got a new/better batch of lens. Overall, the E07 is still one of the best single cell flashlight money can buy.
For the E07v2, I hope to see a slightly longer battery tube with longer springs with better mechanical properties so it does not get permanently crushed when using longer batteries; permanently deformed (shortened) springs results in poorer electrical contact, higher resistance, and less output.
I sent my Copper E07 to the US facility over a month ago after it broke and I have not received any word of anything yet. I have tried emailing Jacky and have not heard back.
Now my Brass E07 is completely dead too.
What is going on with this? Is anyone having such a bad experience as me? Has anyone heard from Jacky recently?
okay wow…… thats just not acceptable at all… zero communication. not sure what to suggest then…. shame u sent it and didnt do a paypal refund instead….
it seems they dont stand behind their lights or honor even warranty like imalent… i have one light that works and doubtful i would buy anymore after i read stuff like this….
I just heard back from Jacky. I will be sending him a video and hopefully he will be checking up on the status of my Copper E07. I will update as this is dealt with.
I don’t know how the Brass died, it had very little use. One morning I woke up and the AUX leds were off, I then trouble-shot it but nothing worked, just a totally dead light.
The Copper had a number of issues. Wrong Aux installed, dead aux lights in switch…. can’t remember the rest honestly I’d have to dig up the old emails.
It seems it would fit the Fireflies E07 and has many different angles to choose. The seller told me they have a MOQ of 500 pieces with 0.27$ per optic. They don’t sell smaller quantities for personal use. I haven’t found this optic anywhere else.
Even if the position of the LEDs is correct, the position of the optics legs isn’t. In the one you showed there are 3 in the middle, and originally there are 4 on the edges in addition, forming a rectangle.
I tested my two new E07 additions with the Texas Ace Lumen Tube calibrated with Maukka lights and Sekonic C-800-U spectrometer. Lumens taken at 2 seconds.
E07 Copper XP-L HI 5A
Turbo
7,112 lumens
4252K
-0.0047 DUV
72.2 CRI
-17.2 R9
45.9 R12
67 Rf
98 Rg
30T
Mode 7
2,397 lumens
4157K
-0.0041 DUV
72.1 CRI
-17.6 R9
45.6 R12
67 Rf
99 Rg
30T
Mode 6
976 lumens
4067K
-0.0030 DUV
72.4 CRI
30T
Mode 5
373 lumens
3956K
-0.0010 DUV
72.8 CRI
30T
Mode 4
171 lumens
3958K
-0.0010 DUV
72.8 CRI
30T
Mode 3
66 lumens
3945K
-0.0008 DUV
72.8 CRI
30T
Mode 2
16 lumens
3947K
-0.0008 DUV
72.9 CRI
30T
Mode 1
3 lumens
3908K
-0.0004 DUV
73.0 CRI
30T
E07 SST-20 4000K FA3
Turbo
4,310 lumens
4120K
-0.0038 DUV
95.5 CRI
86.7 R9
84.3 R12
92 Rf
103 Rg
40T
E07 SST-20 4000K FA4
Mode 7
1,750 lumens
4165K
-0.0010 DUV
94.4 CRI
87.4 R9
82.0 R12
92 Rf
103 Rg
40T
E07 SST-20 4000K FA5
Mode 6
752 lumens
4159K
0.0001 DUV
96.0 CRI
40T
E07 SST-20 4000K FA6
Mode 5
324 lumens
4055K
0.0006 DUV
97.8 CRI
40T
E07 SST-20 4000K FA7
Mode 4
148 lumens
4045K
0.0004 DUV
97.8 CRI
40T
E07 SST-20 4000K FA8
Mode 3
58 lumens
4058K
0.0003 DUV
97.8 CRI
40T
E07 SST-20 4000K FA9
Mode 2
14 lumens
4072K
0.0001 DUV
97.4 CRI
40T
E07 SST-20 4000K FA10
Mode 1
3 lumens
4076K
-0.0001 DUV
97.0 CRI
40T
The FA3 tint bin is the rosiest SST-20 4000K I've seen to date and I've seen MANY! It's better looking than the FD2 in the FW3A, FB4 in the Emisars, FD2 in the Mateminco/Astrolux, FB4 in the Acebeams but it is still nowhere as rosy as the XP-L HI 5A tint, which is perfection. The copper E07 is gorgeous! It's a must own for any flashaholic! Goes really well with the Red Aux light IMO. Also this time around UCL lens didn't improve the tint much. Only dropped DUV by about -0.0003 to -0.0004, which is not noticeable at all. The UCL lens improved tint much more in the older E07 batches. I guess the lens used in the recent batches are improved from the older batches.
Edit: I just realized that the optic used in my latest two E07 is narrower throw than the optic used in the older E07. Comparing my new E07 SST-20 with older E07 SST-20 and comparing my new E07 XP-L HI with older E07 XP-L HI, it is very obvious that the hotspots from the newer E07 are smaller compared to the hotspots of the older batch of E07 using the same emitter. However, I cannot tell a visual difference in the optics.
So my (new to me, bought used) e07 has crushed the top of my Sofirn 21700…was there any resolution to fixing this issue? As far as i can tell, my version is one of the newer models…
