How is it a scam when nowhere do they mention Panasonic. You’re kind of asking for it when you go for a cheap price.
Yes, they’ve used the Panasonic wrap but these are details you need to be aware of. These are all over the place now. They claim 100% original but this is referring to the brand like Liitokala, Varicore etc.
I made the same mistake when these were first introduced to the market 5yrs ago but I purchased 50pcs. I was pissed at first but realized when I went to open a dispute that Panasonic was never stated.
Bottom line it was my own fault for seeking a cheaper than usual price.
Just wanted to share my experience with NKON. I’ve bought cells from them on multiple occasions and never had any problems. Genuine cells and all exactly at the same voltage (ordered 3 vtc6’s and they were all at 3.67V). Very good prices as well.
Has anyone in UK tried ordering li ion batteries from banggood. There is a new option called “Standard Mail Register” and cost more than the options like “Priority direct mail” you would usually see. This is the only shipping option available. Banggood support said it’s fine cause if the item was prohibited it wouldn’t let you place the order.
I’m looking for the flat top shockli 5500. I bought a button top pair from torchy but the button doesn’t make good contact in an FT03 which makes the spring hot.
We recently launched a brand new 2200mah battery. Our goal for the next 18 months is to bring the cost of cells down to below $200/kwh.
We’re currently using a slight variation on the standard chemistry to get prices down to $315/kwh, which is significantly better than most of the other batteries that are publicly available.
Please note that due to the modified chemistry, the safe discharge rate is only 6A. If you need to draw 30A, this is not the battery for you.
Hey there! I’m recently just has bought the SHOCKLII 26650 5500 30A Black one from Aliexpress. I received it and all good to go.
But when you look at its 26650 column/page, they had another version 26650 which wrapped green labeled as 5250mah 20a/40a. Yes, what cought my attention is the discharge mark, 20a/40a. I am aware of HKJ test with the mentioned battery, but could it be really a high discharge battery compared with theblack 26650 30a???
Are these Panasonic NCR 18650GA 30A 3.7V 3500mAh genuine?
If so, very good price. #Aliexpress NOK 18.62 18%OFF | Panasonic original NCR 18650GA 30A discharge 3.7V 3500mAh 18650 rechargeable battery flashlight flat-top lithium battery
