Any plans to for more 21700 host pills/heads similar to Convoy S11? The C8TT head was a great thing. Now, with the Convoy M21A there might be another 21700 host worth the efforts?
I have got several requests for S11 quad spacer set. I think I need to make small groupbuy.
Since Im trying to minimize my stocks (both parts and materials), I wont make many extras.
Im out of 30mm Cu rod, so copper version will consist from 2 parts like here:
Cu+brass set: $13, ~90gr bare weight
VaKo you just came to make the n00by move. Please fix your previous post. Posting big images without specifying the relative width parameter breaks the forum page layout for all devices whose screen width is lower than the image's. Use 100 (%) maximum please.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
VaKo you just came to make the n00by move. Please fix your previous post. Posting big images without specifying the relative width parameter breaks the forum page layout for all devices whose screen width is lower than the image’s. Use 100 (%) maximum please.
My apologies, used to forum software doing that automatically and I have an ultrawide.
I still have many single pills and triple spacers, if anyone needs triple pill I can solder spacer and single pill together and drill a through hole so they could replace a regular triple pill.
Have made several triple pills:
S11 sets will be ready next week.
These are for S2+?
What is price and weight?
Not seeing these listed in the OP.
As mentioned before, this design was not my first choice, but now it looks like most user-frienly quad mod. I never liked soldering driver wires to pcb when it sits down inside deep (yes sometimes 6mm is too deep) pocket, when you are not able to put solder tip at the angle youd like to. With this design there are no such problems, you can solder spacer to brass pill and pcb to the spacer (and even leds to the pcb) within one heating cycle, put driver and solder wires, slide outer brass ring over spacer when all soldering is done and screw whole assembly inside head.
Kiriba-ru, I was hoping to get three of the copper p60 quad drop-ins here at the end of the month. I see there is only one left now. Any plans to make more?
as a beginner modder, can you help me understand what do these parts do, and possibly the instructions of them (to see if it is in my skill level)
It appears out of your list of items, I might be interested in S2+ and sofirn C8T
Hoarding is a behavior where people or animals accumulate food or other items.
If you add a spacer to S2+, you can change one led to three leds (mounted on 20mm triple pcb) with carclo triple optics (10507 is the most popular option).
If you replace brass pill with copper one, you can increase heating mass and improve heat transfer.
C8TT was developed to show how fins (placed wide) can improve heat dissipation (not as much as most think). In my experience, C8 with my finned head can carry 2 times more power as regular C8 can.
A triple spacer for the FW1A might be more interesting.
You know there’s this light called the FW3A?
I agree, seems like people want to handle heat on this light but the body of the fw3a is paper thin and I suspect you wouldn’t be happy in an extra large pill to distribute heat
I think that’s a great idea. FW1A is only 8.3mm longer. By inserting a copper spacer inside, you can significantly increase performance.
I had two FW3A pieces from the first batch with a black clip and sold them, among others, because of the “paper” shelf.
I will send a pm soon, thank you.
Acebeam L18, Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Emisar D4, Fireflies E07, Jaxman E2L, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Olight Baton 3, Olight Warrior Mini, Olight M2R Pro Warrior.
Most of them have been modded! =)
https://photos.app.goo.gl/JaJaDv4V838AEJf39
Привет кирилл,
Большой привет
Томас
Lux-Perpetua,
Here you go:
FT03 + ?? board (redacted) + https://www.ledil.com/product-card/?product=C13236_SANDRA-12-S
No plans. I need to sell stocks.
I will think how to modify C8TT for modern hosts.
I dont think 12 led series module is suitable for flashlights.
Low-cost copper pills, spacers, optics, drop-ins.
Good eye, I saw a “P” on the board but it’s actually 6S2P or 12S
Dammit, missed the S11 spacers. Oh well.
List of my reviews over at 1lumen.com
oweban.org
I’m in for two S11 spacers!
Some test fitting while I wait on LEDs
C8TT with ANNA mod. Shaping up to be one of my favorites!
Finished product:
Solid copper spacer, 6x Luxeon MZ 5700K.
Wow how many amps on DD FET? Gotta be 35A with a good battery
These are for S2+?
Thanks
Yes.
PMed details.
need 3x singles, pmed you
Hi kiriba-ru, I would like an M2 aluminum set please. Thanks
I’d rather use my flashlight around the house than turn on the lights.
2pcs available for sale.As mentioned before, this design was not my first choice, but now it looks like most user-frienly quad mod. I never liked soldering driver wires to pcb when it sits down inside deep (yes sometimes 6mm is too deep) pocket, when you are not able to put solder tip at the angle youd like to. With this design there are no such problems, you can solder spacer to brass pill and pcb to the spacer (and even leds to the pcb) within one heating cycle, put driver and solder wires, slide outer brass ring over spacer when all soldering is done and screw whole assembly inside head.
I have few more rejected. PM if interested.
Any parts for Fw3a? Looking for everything that goes into the head and upgrading from stock
Big PLUS 1!!!!!
WTB Titanium 4sevens 2xAA tube
Big price drop for S2+ spacers and pills.
