We recently launched a brand new 2200mah battery. Our goal for the next 18 months is to bring the cost of cells down to below $200/kwh.
We’re currently using a slight variation on the standard chemistry to get prices down to $315/kwh, which is significantly better than most of the other batteries that are publicly available.
Please note that due to the modified chemistry, the safe discharge rate is only 6A. If you need to draw 30A, this is not the battery for you.
Hey there! I’m recently just has bought the SHOCKLII 26650 5500 30A Black one from Aliexpress. I received it and all good to go.
But when you look at its 26650 column/page, they had another version 26650 which wrapped green labeled as 5250mah 20a/40a. Yes, what cought my attention is the discharge mark, 20a/40a. I am aware of HKJ test with the mentioned battery, but could it be really a high discharge battery compared with theblack 26650 30a???
Are these Panasonic NCR 18650GA 30A 3.7V 3500mAh genuine?
If so, very good price. #Aliexpress NOK 18.62 18%OFF | Panasonic original NCR 18650GA 30A discharge 3.7V 3500mAh 18650 rechargeable battery flashlight flat-top lithium battery
Look at that
I’m on the hunt for genuine brand cells with good capacity and 10A continuous for 2 bucks a piece.
I have found them at i.e liionwholesale but they’re sold out.
Just a note — Nealsgadgets doesn’t ship loose cells to the US anymore. The order will complete, and the money will transfer, but will go into indefinite limbo with no feedback as to why.
Watch out for the newer LTO (lithium titanate) chemistry cells. There are good genuine Toshiba SCIB cells and genuine 66160 YinLong cells but also many poor quality pouch cells and 66160 cells that have been recovered, typically with other brand names such as GTK.
Now, GTK IS NOT a manufacturer, but a wholesaler of re-wrapped cells - these are sub-standard and often second hand. I purchased 100 X 66160 40ah LTO cells only to find out they were old used YinLong cells that were lucky to test out to 27amps and many fail to hold full charge. That was a $7,000 hit that Kevin Lee from Shenzhen Foxell Technologies Co., Ltd & Shenzhen Foxelion batteires Company Store on AliExpress sold me. The other was from the same store, 160 X 12.5ah LTO Pouch cells. They tested out to 10amps and 65 failed on their first use. I found the original manufacturer “Microvast” who stated these were “trash” waiting for recycling or disposale (obviously being sold out the back door). That was another $3500 hit to my pocket. Kevin Lee is denying these claims but completely unwilling to work with me on a refund or resupply of the correct cells. Be warned, DO NOT BUY FROM the Shenzhen Foxell Technologies Co., Ltd & Shenzhen Foxelion batteires Company Store on AliExpress! …that is unless you like trowing your hard earned cash down the drain?
I see too many people bypass my store to save a couple $$ only to end up disappointed. Just recently a customer purchased 400 Chinese cells which he thought was a better deal then my price, ended up 1/4 the claimed capacity. He’s building e-bike packs for his customers, thought he would have known better
