Ahh, ok - I took off the bezel and optics on mine and see the 4 different colors. RED is only lit if it's at low voltage.
In order from outer to inner:
- GREEN (high)
- BLUE (D1)
- PINK (D2)
- RED (Low)
Weird labeling but it works!
Received mine yesterday. Green, 5K. Yes it’s a little green in low levels, but not such disturbing in real life (I walked for half an hour yesterday night in the wet fields around the house…) exept in front of an absolutely white wall…
Nice quality, flawless…
Very nice little light, with too many abilities as it is…
The faster hand warmer I have !!!
Thanks freeme, it was an absolutely well worthing waiting…
I received mine (Gun Metal/4000K) on Monday, had a bit of time playing with it and am impressed.
I think the aux leds are a bit busy-looking, but because they serve a function, I’m not bothered. I’ll try tweaking them this weekend.
I’m not a big fan of on-board charging mainly because of the way a rubber cover can let in dirt or moisture. I’ll most likely keep this light away from the harsher elements and use it around the house and property. For backpacking, I’ll use a lighter and smaller light anyway.
It fits my hand nicely and is fine for a jacket pocket. No sharp edges or flaws anywhere. I gave up some lumens to have a warmer tint and I like the tint a lot. It’s still a powerful package and a nice mix of flood and throw. I’ll bet they’ll sell a heap of them.
I had to fish around with my tools to find a small enough screwdriver, but I had no problem adjusting the trimmers once I did. I turned down everything except green and it looks less busy now.
I used the light for a while tonight and I am glad I made the purchase. I was going to hold off on the first run but I see no issues with this light.
I also like the way it can use a 26650, 18650 and 21700 cell. Nice job Astrolux. I’m using a Shockli and I doubt I’ll use anything else, unless some sort of extended use situation comes up. Nice though for folks to have choices.
Anyone else pulled the driver yet? I’m assuming it’s de-solder the AUX and emitters; there didn’t seem to be enough give to bring the board out enough to get at the MCU.
Will also do a reflow at some stage with new emitters
Yes, just a couple pages back. You undo 5 wires. ✌ FREEME- ASTROLUX MF01 Mini 7*SST20 CRI95 26650 ANDÚRIL Flashlight Group Buy - $45.99 - #1261 by Chatika_vas_Paus
Ah thanks - missed that somehow.
Cheers!
Thanks Freeme! Ordered two more in tan and gray! My green one showed up today and everything if functioning great! My new favorite light. I just got my Acebeam X45 two days ago and its a great flashlight but this MF01 mini is amazing! I love the UI! Ordered three diffuser as well.
Thanks for the info above on the trimmers. I have one last question before I adjust them. To increase the brightness of the aux leds, do I need to turn clockwise or counter clockwise? Maybe the light is more durable than I’m taking it for… I’m just worried I might break it!
The trimmers will move quite easily - you’ll know if it hits a stop. That said, some will spin continuously, but will go from 100% to 0% in a tiny turn(like hitting 12:00 on a watch).
Clockwise increases brightness, from memory.
never have enough torches i like the look on the 7 led just bought one Astrolux MF01 Mini 7
Freeme could you ask if there will be spare parts available for this light? I am interested in a copper MCPCB
Thanks!
MCPCB costs $3 from Mateminco store, but shipping is $9.5, or for free if you buy it with any flashlight.
Thanks! Sent them a message for a MCPCB with leds quote.
What are you going to do with it?
I plan to do XPL-Hi 3a tint, but Osrams are tempting…
Just received my silver 5000k today. Yes, I wish I had chosen the 4000k. On low very low modes it’s about as green as my thrunite archer 1a, which is quite horrendous. Of course on higher modes it’s not noticeable as others have mentioned. I think I can but up with it; the tint is not soooo bad unless it’s compared to my 4000k C01s (but to be fair, all my lights look bad compared to my C01s tint). Also the silver/aluminum color is not bad. Not as nice looking as the stainless steel bezel, but close enough. I think it would look better just a shade darker on the silver.
IMO Anduril, USB charging, and kewl auxiliary LEDs make up for the 5000k tint.
Ultimately I’m nitpicking on the aesthetics of a tool. This rides the line between tool and toy, and I like it.
I’m going the sw45k route - drops a lot of lumens but dear lord the tint and CRI
Yeah, the SST-20 5000K green is certainly noticeable when white-wall-hunting, but it’s not bad at all outdoors in the real world.
Hi. I got my 4000k, at first i was happy but the voltage reading is incorrect at 4.2 shows 4.1 and at 4.15 already to 3.9v. My emisar and FFeo7 are sharp on this. The other issue is with thermal sensor at max ramp it steps down extremely fast to about 500lm maybe less than minute and it is calibrated to go to max temperature at 60 Celsius and when i go on turbo it is more sustainable. Is anyone noticed this step-down. I guess that sst20 at 4000k produce more heath but there is an issue here, to me it’s like that in max ramp it doesn’t know that i upped the step-down and it stays in default but in turbo it get it.
