Progress on the aesthetics is slow. Mainly because I am not making time to work on this project. When I do work on it I need to go slow, double check everything and make light cuts (read many cuts/passes). My last build, the mokume one, it turned out quite heavy because 1. it’s made of copper and nickel (both as heavy as each other) and 2. I kept a decent amount of wall thickness in the body so it didn’t split like the bezel did. This build I’m hoping it won’t turn out as heavy. At the same time i’m trying to make the most of the superconductor pattern. Still lots to go…
I noticed when turning it down that the copper cut smooth and shiny but as soon as the niobium titanium appeared the cut seemed rougher all over.
I realize the cone shaped tail won’t be the most comfortable shape to hold when screwing/unscrewing but this light is less about the feel and more about the looks
One of these days you guys are going to make me buy a lathe because of your awesome work… and my wife will put me outside for good.
This project has been very interesting from start to finish. Great work pinkpanda3310!
Thanks f0xx. If you ever do end up in the dog house I’m okay with that. Just make sure to show us pics of your new lathe
A little more shaping today. I put ripples in the body mostly because I’m not a big fan of smoothy bodies. I don’t know if that was such a good idea. It kinda detracts from the patterned metal. I was previously thinking of turning the tail down narrower than the head to try and balance out the look of short stubby head. I had a change of heart when I saw the pattern on the fat tail and kept it. So now it all looks a bit weird. I did some test fitting to see how it looks…
It is different, looks good
I wasn’t happy with the shape / balance so I decided to remake the bezel. I actually tried to make it on sunday but my head was a bit fuzzy from having a cold and not long into making the part I screwed it up by turning it down too far I was feeling better and had some time this afternoon so gave it another shot.
Doh! I just realized I haven’t shown the internal organs in place either. I had lots to talk about my thought process on some parts but I don’t really want to spend too long on the pc right now so the pics will have to suffice.
I still need to do some stuff to the new bezel. I don’t like the beam but i’m too lazy to change it. Will get a shot of that later.
Will be away over the weekend for another bicycle race (this one’s on road) so will be another break before next update.
Progressing nicely
Very Nice pp ,your attention to details is Awesome
how do place the photo’s in a grid? when you post.
Just set all the pics to 30% width
This is turning into a real ripper pp. Love the style.
Worked on the bezel this arvo. Looks much better now. It also fits the optic. Last time I test fit the optic into the bezel while it was still mounted in the chuck. I think the bezel had expanded from heat because the optic fit fine but when I finished the lathe work and mounted on the host the optic did not fit anymore It fits now but I need to use something to hold the optic from spinning whilst fitting the bezel.
Nice to see progress.
That is an item of extreme beauty. Having a light inside is a bonus……. I’d happily look at it empty lol! Looks like Leopard skin.
Lol, one of my daughters likened it to a giraffe. It’s a good thing if it’s being percieved this way because I wanted to make the best of the metal pattern. Of the other superconductor ligths I’ve seen the pattern mostly straight up and down lines
@pinkpanda3310:
I cannot see any of your pics in the above post.
Me neither, but the others make up for it top job pp
See pics?
Yes, now I do.
Thanks!
I was laying on the lounge floor with this light in my pocket. I took it out so I could lay on my side and placed it underneath the table. I thought that’d make a cool pic….
The bezel is the same diameter as a D4 but the optics sit deeper
The bezel has some marks from the last time I worked it in the lathe and the tail still has machining marks but other than that I think I’m done. I tried to get a ceiling beamshot to show the beam shape but it didn’t turn out so good. Will try for beamshots again later.
