Bending s-hooks would work well. It’s really not that big of a deal, and certainly won’t effect my usage of the lantern. But if it can be adjusted easily, then I’ll do it.
Yours look good. On mine (and I notice on some of the batch 1), the “6” & “7” have solders on them but were unsoldered (but still leaving solder residue)…
You need a swivel device. I’ve seen some just can’t recall the exact name. Set it at the position you want then wrap the swivel with some clear silicone tape to fix the position. ???
There is enough slag in the wires going to the MCPCB, but the wires are twisted in the driver cavity so you can not pull them upwards from above. You can unscrew the driver, untwist the wire bundel and then tighten the driver again. Then the top can be be lifted much higher and everything is in reach.
I was waiting to get a PM with my GB code. I never got one. This whole GB process was very confusing & it seems many people were able to “jump the line.” And now the 3,000 units allocated for the GB is closed? I saw that the auction listing for the version with batteries still had some inventory so I submitted an offer for it, but not hopeful…
Success getting the bale lined up with the button. djozz had it right. Take the screws off the driver and un-twist the wires. Pull the bolt off the top and lift. With plenty of room, you see the two tabs DBSAR was talking about. It’s soft plastic. I just grabbed the tabs with pliers, snapped them off, then cut the left over tab with a sharp knife.
As DBSAR mentioned, the o-ring was a bit tricky to get back on. I rolled the o-ring down onto the shade, then slowly rolled it back up to seat on the top of the shade. Lined up the top cap and replaced the bolt.
Putting the driver back in, take a sharpie marker, and mark where the charging port is, so you can line it up. Twist the wires back up, line up the charge port, and put the screws back in.
Driver off, un-twist the wires
Pull up on top cap, and snip off the plastic tabs on the center post
Mark the charging port with a marker, twist the wires back, and install screws
DBSAR and djozz both get the credit ! Just remember, if and when you change the batteries, to grab the head around where the button is to unscrew the battery tube. If you grab it by the top cap, you risk twisting it since the stopper tabs are no longer there.
I guess the diffuser is epoxied or some how else attached to the base for protect against water intrusion? Else it seems like one could just rotate the diffuser/top to line up the bail with the switch, and not have to cut the tabs. Not really sure the tabs are needed, but perhaps are part of the normal production assembly process.
I should have looked at how the diffuser was attached, but didn’t. I believe it is screwed into the base and an o-ring between the bottom of the diffuser and the body. I can definitely see why they put those tabs in there, to keep from rotating the top cap where the MCPCB is attached, thus, preventing further twisting of the wires.
The base of the diffuser has 3 screws that holds it to the base. I was thinking of trying to turn it that instead. I just cut the tabs and was able to turn it so it matches with the button. Added some loctite to the bolt but it probbly won’t back out on it’s own anyways.
I completed the mod, took about 20 minutes? Would have been quicker but I added a twist, not really sure if/how much of a difference this makes. I put aluminum foil over the center diffuser post. Figure whatever light might have gotten absorbed there is now reflected. Hard to say if its any brighter or not, but it can’t hurt. The foil extends from the base to about 1/4” of the top, just cause that’s how my cut ended up. It would be interesting to compare this LT1 with another now.
Ha, I asked about this exact mod being part of a potential future production run or if it will be a one-off thing. Though looking at how the lantern functions, it’s probably only a few lumens different.
Just a small warning: the protective tabs on the bottom of the 18650 cells shipped from Sofirn can leave glue after them. Noticed that when I popped them into a charger and one of the cells didn’t charge correctly until I cleaned the bottom connection properly.
