Malfunctioning MF01S
21 posts / 0 new
ricksp65
Last seen: 3 years 2 months ago
My astrolux mf01S seems to lock up in a slow blinking mode and the only way to stop it is to disConnect contact with the battery and it will operate normally for a few tries but then gets stuck once again any thoughts? Thanks
Edited by: ricksp65 on 11/02/2019 - 17:37
Lexel
Lexel's picture
Last seen: 2 years 2 months ago
It’s a know Anduril issue related to switch bounce, especially 2S lights seem to be affected a lot more
I had it also on 1S lights
a small MLC capacitor of like 0.1uF directly soldered on the switch can fix it
ricksp65
I did contact banggood but they don’t seem to be very receptive when it comes to returns or replacements I’ve only had the light a couple weeks I haven’t heard anything back from them yet. But I guess repairing it myself could be an option if There’s no other way I do like the light though it would’ve been one of my favorites if this didn’t happen .
Lexel
Lexel's picture
Unscrew switch and solder cap 0603 for example, not sure where exactly to solder but easy to probe the switch
ricksp65
Kind of hard to imagine not replacing a product with a known defect. I guess I should’ve purchased it from Amazon they seem to be better about returns and replacements.
Lexel
Lexel's picture
Switch bounce problem is kind of odd most lights don’t show it
ricksp65
I only found one video on YouTube besides mine showing the problem.
ricksp65
Lexel
Lexel's picture
I hope Toykeeper will release a fixed firmware revision
NarsilM works flawless if you may want to flash different firmware
ricksp65
I have no idea how to flash software I just collect flashlights that I like I’m not really too much into the workings of them. I guess this one will be relocated to the drawer in the garage it didn’t make the grade to go on the shelf with all the really awesome flashlights.
d_t_a
Last seen: 1 week 3 days ago
Lexel wrote:
It’s a know Anduril issue related to switch bounce, especially 2S lights seem to be affected a lot more I had it also on 1S lights a small MLC capacitor of like 0.1uF directly soldered on the switch can fix it
I have already many Anduril flashlights, but so far haven’t encountered this issue.
I would like to know how often do these kinds of “issues” or “bugs” happen? What is the cause?
Do they potentially affect all Anduril firmware flashlights (at least until a new firmware to workaround the said “bug” is released)?
Lexel
Lexel's picture
the issue is known by Toykeeper and its confirmed switch debounce code who can get stuck in a loop
any flashlight with this issue under Anduril could be tested with NarsilM working without that problem
ricksp65
So how do I get it fixed?? Or replaced? I’ve only had it less than two weeks? And what is a toykeeper?
BlueSwordM
BlueSwordM's picture
Last seen: 17 min 18 sec ago
Toykeeper is the person that makes the code of the firmware that runs your light.
ricksp65
Found an article that deals with this I think I figured out what’s going on here . https://www.allaboutcircuits.com/technical-articles/switch-bounce-how-to...
ricksp65
Well I think he needs to put that one back in the oven to bake for a while. LoL
ricksp65
The GF likes the pretty lights I wish I could take that board out with the colored LEDs and put it in one of my better lights but I don’t have the skills.
ricksp65
Has anyone else had any luck with returns and replacements from Banggood? I noticed they do a lot of advertising on this forum.
klrman
klrman's picture
Last seen: 3 weeks 6 days ago
I think BG has a US warehouse, so for you it may be very easy to return it.  Normally, if you can get the same deal for a light on Amazon, it's always way easier to return.
Lexel
Lexel's picture
MF01S Aux board will not even fit MF01, not to mention any other light
I have for some lights aux board as in my signature
AbnInfantry
I apologize in advance for the long rant I’m about to post regarding my defective Astrolux MF01S. After waiting for over a month for the light to arrive from Banggood, it was finally delivered in the mail last Saturday. I thought it looked great with the blue anodized finish and, initially, the MF01S worked properly. I own several lights with Anduril firmware (Astrolux MF01 Mini, Lumintop EDC18 and FW3A, Fireflies EO7) so I’m familiar with how they’re supposed to work. Within an hour, my MF01S began malfunctioning. Over the next two days, it would work correctly for one or more hours then, for no apparent reason, it would suddenly become erratic. I mean seriously malfunctioning. I’ve cleaned/greased all the threads, cleaned all contact points, and ensured the head and tail cap were screwed down tight.
For over three hours one night, it was impossible to turn off the MF01S except by partially unscrewing the head or fully unscrewing the tail cap. For the past five days, the light has continually malfunctioned every time it’s been turned on. Clicking the side switch once to turn it on results in: the light ramping up or down in brightness without my finger holding (or even touching) the button, activating one of the strobe modes, rapid flashes or a variety of other incorrect behavior. With the light on, two clicks which should activate Turbo instead causes the light to: ramp up or down in brightness, engage a strobe mode, decrease in brightness, do nothing or turn itself off. For the past five days, three clicks do not give a battery check and four clicks do not turn on or off lockout mode.
All I’ve ever used any of my Anduril lights for is to ramp up or down to a particular brightness, and engage Turbo or tactical strobe. I’ve never tried to use Momentary mode, Muggle mode, change any temperature setting, change the default ramping levels or any of the advanced features possible with Anduril. This light sometimes changes from smooth ramping of brightness to graduated step levels without my clicking three times. Sometimes I can, eventually, get the light turned off by clicking the side switch; other times I have to partially unscrew the head. Most of the time, the side switch feels like those of my three MF01 Mini lights. Occasionally, however, merely lightly touching the rubber button will cause the light to react as if it was clicked. After I got this light turned off, it has repeatedly turned itself back on when I didn’t press, or even touch, the switch. It’s turned itself on a few times when I wasn’t even holding the light. I have no idea how this is even possible.
I don’t know which has been more aggravating: the hours I’ve wasted trying to get this defective MF01S to work properly or my experiences with Banggood Customer Service after reporting the issues I was having with their product. At their request, I provided Banggood with videos showing the MF01S obviously malfunctioning and pictures of the shipping labels, SKU code, and batteries I’m using. I’ve tried eight new, fully-charged Samsung 30Q cells I purchased from Illumination Supply. Normally, I use four flat top Samsung 30Qs. I also tried four button-top Samsung 30Qs; they made no difference.
Banggood CS told me to perform a factory reset as described in the User Manual. Nowhere in the User Manual that came with my MF01S is there any mention of a factory reset. I read online (including posts by Toykeeper) describing two methods of doing a factory reset with an Anduril flashlight. I performed, or at least attempted to perform, such resets numerous times. The MF01S immediately continued to malfunction as soon as power was available. Even if a factory reset was successful, it would only return the light to its original default settings. A factory reset doesn’t magically repair a faulty side switch or defective circuit board.
Banggood CS suggested I allow the flashlight to “cool off” and directed me to adjust the light’s temperature. This MF01S constantly malfunctions the moment it’s turned on, even if it’s cool from not having been used for over ten hours. So heat is not the problem. Since I can’t get the light’s sole control mechanism to correctly operate for basic functions, I certainly can’t get it to access temperature config mode.
Banggood CS asked me to contact a “local service shop” and obtain an estimate to have the MF01S repaired. Ignoring the fact I’m sure no such shop exists in the South Dakota town in which I reside, Banggood CS said the shop must not disassemble the light in any way since “disassembling will cause invalidation of warranty.” How could any skilled person capable of making repairs on an electronic device even offer an estimate without opening the MF01S to examine it?
After I opened a PayPal claim, Banggood CS offered me a $40 refund. Since I bought the light on sale for $80, that means I’d be stuck with a constantly-malfunctioning $40 flashlight which is completely useless to me … except serving as a paperweight. While I’m hopeful I’ll eventually get a full refund via PayPal, the many hours of frustration I’ve experienced over the past week with this defective MF01S and Banggood CS have been highly aggravating.
