I got a sample of 10 of his high CRI 5600K leds from rngwn in this week and I did some testing.
First a beamshot from 20cm distance from the wall:
Actually this shot looks nicer as in reality, the beam is indeed really smooth but there is a slight tint change at the very edge but it is nothing serious, at least not so bad as rngwn’s own beamshot in this thread.
So the tint is really really good and does not change much at different currents.
The light output. I made no graph (not enough time) but a video. You see the led shining at a luxmeter that I placed at a precise distance so that the luxmeter reading is quite exact 10 times the output in lumen. So a reading of 93 corresponds to 9.3 lumen total output. The voltage and current can be read from the USB power supply. I checked, they are not greatly off from reality.
So, like the 3400K led, it maxes out at about 120mA (25 lumen), but above 80mA (22 lumen) there is not very much gain. This is a very nice performance, at a bit but not much better than the Yuji 5600K led.
As discussed via PM also, I expect a good market for high CRI 3mm leds, especially at warmer tints. Of course over here we like them anyway because we like all leds, but in model building (trains!), perhaps a bigger hobby than flashlights worldwide, a lot of use is made of 0603 and 1205 leds, sold on ebay with two wires already attached because soldering them is too difficult for most, while the application of standard 3mm leds is more robust, way easier and often looking better. I have one time bought warm 3mm leds (was not easy to find) and the tint is quite disgustingly yellow-green, I would not like to light my preciously built railroad yard with those.
But I’m not a model builder and do not know one so perhaps someone else can confirm?
These LEDs look nice for sure, but what about super short life time of 5mm LEDs (caused mainly by yellowing/burning plastic LED lens which is not resistant to heat like silicone)?
Most 5mm LEDs are rated ~20mA max. because of bad cooling and plastic lens burning problem. Many will drive these at much higher current, what is expected lifetime in those cases?
Thanks for that info led4power, I did not know that. The graph is very convincing, and overdriving 5mm leds makes it much worse. Not that lifetime matters greatly for what we hobbyists do here, my Nitecore Tube is used for 3 seconds once a day to look into the letterbox, but if we do serious builds for Nasa it does matter a lot.
I don’t have data for this particular LEDs, but a very old “fade test” data from CPF do suggest that a really well-made 5mm LEDs (radioshack’s) might happily last 50k hrs at 30ma.
For Nichia-tier LEDs, they would last ~5000 hrs at 30 ma (at L70 a.k.a. leds considered “failed” when the brightness drops below 70%)
The thread also mentioned that, LED lifespan increases 4x for every halved currents.
For these LEDs though (which is now known to be more efficient than Yuji’s and probably many standard 5mm LEDs), my educated guess would be at least ~4000 hrs at 30ma/ ~1000 hrs at 60ma L70. For occasional usage (i.e. 1 hours/day) that will take years until the degradation becomes apparent.
Got a notice from the post office in my mailbox yesterday
I have no idea why that time they droped a notice in the mailbox instead of the parcel like for the previous leds but i was lucky enough to be able to go there today (as i am usually working during opening hours) and take the parcel.
It looks like it was opened (customs ?) but everything is fine and i am happy with the leds :)
Last shipping update on mine, according to USPS is that it departed “SUVARNABHUMI MAIL CENTRE (SMC), THAILAND” on November 1st. No idea where it went from there.
- The shipment is on the queue to be loaded on the airplane at SMC (which will then head to the States).
The shipment has already landed at LA or JFK (or Honolulu if shipped to Hawaii), but is still being unloaded from the warehouse to be scanned.
Once it’s scanned by USPS it will appear as “Processed through facility” at either LA or ISC NY before heading to the customs.
Whatever case it will be, once it shows processed at SMC, it will usually take 3-10 days to appear in the USPS’s tracking as arrived in U.S (in the case of Airmail/ePacket during non-seasonal period).
Is it possible to get these in 2200-2700K too? I have a lot of LED candles that I want to change out the LEDs on. Could possibly do a group buy if others are interested.
As far as customization goes, 10k would be a minimum, and the binning will be all over the place, and some or even much of these might not be marketable. I find this quite a bit messy for my liking.
I think that even with grossly inaccurate binning there maybe enough people to get you to 10K. If I buy a 100 and there will be 30 that have a good tint that is fine with me. Unlike smd-leds, the tint of 5mm leds are simple and fast to check by eye with a plain 5 dollar led-tester.
Maybe you can do it the form of an interest list to take out much of your risk. Estimate an approximate price and divide it in lots of 100 or 200, and see how far the list gets you. If you are close enough to 10K you can try to order them.
I like to see those very warm (2200K?) high CRI 5mm leds becoming available and also warm 3mm leds, I could start an interest list for you if you like?
Well that’s certainly a nice perspective. I probably won’t do this right away, though. You can do the interest list, but I can’t give words on when I would actually do it. Just like how C01 list currently goes
Although, the “messy” scenario I mentioned of is when they do bin the parts and I get some good bins and some bad bins, I will have to somehow sell all of them. In that cases, I will have to deal with several SKUs in the inventory, which is what I think the “messy” part of the ordeal. One thing is for sure, since this is a customized part, the best bins probably won’t come cheap.
It is fine if it will not happen right away. To fill an interest list takes at a month or more so no hurry. For an interest list to work I do need a price indication and which led(s) we are trying to get.
