Yes i checked the temperature ot the flashlight with laser thermometer and it should be correct. The max ramp is about 2000lm 20 steps below 150. So in max ramp it starts to step-down rapidly to about 500lm. When i go to full turbo wich i measured about 4600lm it is more steady and it reaches above 60°Celsius, in max ramp it goes to maybe maximum of 45° Celsius. If you can check is this the case with your unit or it is something just with mine. In my other anduril flashlights at 2000 2800lm they can sustain this for at least 5 minutes or more but here it’s not that case.
That may not be accurate. The sensor is built into the driver, not on the exterior of the light. Heat can stay trapped inside the light long after the exterior is cool. The only way I know for sure is to let the light cool to room temperature at least an hour if it has been warmed up. I typically let it sit overnight then I check what temperature it blinks compared to room temp.
The reason it might be getting hotter on Turbo is due to thermal lag. It takes a bit longer for the heat to travel from the led to the sensor than it does from the led to the exterior. So the heat gets to the sensor slower.
At full ramp you have less heat so it travels a little slower. It may reach the sensor with less lag and start reducing power sooner.
If you have the max temp set to 60* and the internal temp is set accurately then I’m not sure why it starts ramping down at 45* at full ramp. Lower power settings tend to be more accurate. The thermal lag is why the upper power levels have a panic mode. If it senses a quick rise in temperature it cuts a lot of power so as to try and prevent it shooting way past the set max temp.
I don’t have a MF01 mini, my only Anduril light is an FW3A. :confounded:
The only thing I can tell you is to choose which situation is more important and then reset the max temp for that. For example, setting full ramp to stepdown at actual 60* exterior (raise the limit to 75**) might make the Turbo temp go up as well to maybe 75**. Maybe set it somewhere in between? Keep in mind the light can easily handle 100*+ temps, the thermal stepdown is just there for the user to not burn themselves.
You only need to turn it slightly to raise or lower brightness. I doubt you will need to go to the trimmer limits. Is it broke? If it still works, I would not worry about it spinning freely as that makes no difference.
No problems. Just be aware the 5500 lumen rating is only for the CW. The warmer tints have less output (common with most lights). Some say the 5000K is a bit green at low levels. That’s all I can think of. Most reviews are very positive.
I’m not really sure if it’s broken or not. The high and low trimmers never seemed to turn anything on when I tinkered with them. Maybe they are battery indicators that only turn on at certain battery levels?
2 out of 4 SST20-4000Ks have a slightly whiter tint than my other 2. Not as white as the 5000k by far. Those 2 heat up faster as well. Same batteries. They were ordered at once w/o expedited shipping. In green and grey tube colors. Not sure what’s going on.
Hi again. I made precise measurements this time in different situations so i am absolutely shure that the temperature sensor is set correctly it sat all night and checked with laser thermometer. On max ramp it just steps down in 10 seconds it reaches 30° inside. when i double click on turbo everything works as it should it stays with very slight step-down on more than 3000lm for 3 to 5 minutes reaching abive 60°. I played with it and in every situation in ramping it starts to step-down immediately no matter what lumen value, it steps down on 3000lm and in 1300lm equal. There is no issue with setting i have a lot anduril lights they all wait to get max temperature limits to start to step down, here it happens only in turbo mode in every other stage of ramping it immediately hits rock bottom. If smoen have the time it is easy to check this with a lux meter app on the phone with ceiling bounce. Am i only one who have this issue with MF01 MINI.
Jist to ad something wich is weird , when the battery is below 3.7V there is no longer rapid step-down in the same lumens i tried it with 1800lm i put new battery 4.2v and ramp to 1800lm and the flashlight rapidly stepped down, then i put battery at 3.7v and ramp to 1800lm and it holds for minutes with slight fluctuations (the batteries are the same) i don’t what is happening and why, if someone have the knowledge to answer I’ll be happy.
