I just found Hi-Max branded protected 26650's from the same Ebay seller who carries the Hi-Max 18650's. Pretty steep at $27.50 + $7.00 shipping! Link here.
Thanks for the link, Garry. A quick Google search for Hi-Max Electronics and they do not show 26650 as one of their battery offerings, but their website could be out of date if these are relatively new. However, I have a source for H-Max, I'm going to check to see if these are indeed legit.
EDIT: Confirmed with Shane at Protacticalshop19 that Hi-Max does have these and the ones sold by pingyi.co.ltd are indeed real. I'll update the OP to reflect these in the Protected section. Shane also confirmed they use a Samsung core.
Thanks, kramer. I'm not seeing where the Trustfires that Pok tested were purchased. EDIT: Pok responded in other thread that origin of the cells is unknown. I would not consider the Trustfire 'brand' to be tested without knowing source of the tested cells. Too many fake TFs running around.
On DX, I'll change the description in the OP when DX changes the description in their product headline and wrapper. Many folks don't read down into the details....
lols sorry i did have other words in mind that was the sweetest one i could find, ive had a few part refunds from them due to under performing batteries and a torch that tail cap would not screw on due to bad threads, but i was told cause i still could use the items that was good enough. I brought some 3000 mAh nimh after a week of cycling the best i could get was 660 mAh, i have 2400 mAh so 3000 is not to far off just fluffed up, but i did expect around 1800 mAh silly me and usualy less then 50% of the claimed mAh from 18650,s from them, but im sure others have had good luck from them or they might not be testing mAh, IR or voltage sag with hobby chargers or any test equipment. Just my opinion
