Thanks for the review. Got mine back in May, directly from Lumintop, right after it became available. Chose pink for something different. If it had been really really pink, I would not have chosen that color. But it's more like rose gold.
It can actually tail stand - if you don't mind fiddling with it for a few seconds.
Lights like this that twist to connect power have zero parasitic drain. When you twist it Off, the battery is not connected at all.
What Zeroair is refering to in his review is a drain due to leaving the charging cable attached. It’s as if the charging circuit does not go to sleep after it’s fully charged.
If you charge it and then remove the plug there will be zero parasitic drain so the light is fine.
If you charge it and don’t remove the plug there will be the drain.
His charging circuit might be defective or it might be it is just designed poorly. There is also the possibility that the 10mA draw he saw on his usb power meter was a draw between the charging circuit and the usb plug. Meaning the charging circuit is not pulling power from the battery at all. This would make it a non-issue.
Unfortunately, you can’t check the actual parasitic drain due to the sealed battery. My guess is it’s zero. I doubt they would design a flashlight that self drained in 24 hours.
Hmm, that’s a plausible explanation. Unfortunately since the charging circuit is inside the battery side of the light’s body, it’s conceivable that it might still be draining the battery even with the head not connected, no?
Ultimately it would be best to hear from owners on how long it retains a charge.
Ok, maybe that could be an explanation… but I also got the EDC Pico — I got 2 actually, a black and a pink.
The black one has the exact same issue mentioned by ZeroAir (and also in another post I visited), the battery self-drains in about 1 day, after charging it. The charging cable is NOT plugged in the EDC Pico after I finish charging it. I just let it stand (even with the head off), and the battery self-drains.
This occurs on 1 unit. The other unit EDC Pico doesn’t have this issue (at least it won’t self drain completely after several days of not using the light).
But based on the number of EDC Pico with this issue, I would think there is some real issue about the battery self-draining, but unfortunately I don’t know how to troubleshoot it…
Thanks for reporting. The inconsistent quality is quite disappointing. I would hope it could last months without recharging. I quite like the design and form factor.
There are many other brands that have essentially the same design but with different bodies and emitters. I wonder if they are similarly affected. Olight i1R, Wuben G series, Trustfire Mini2, Acebeam M50, and probably several others.
I like the Jaxmnve M1. I have several with no issues, but they don’t have the super bright mode like the pico. They are also a bit tricky to find as their store on Aliexpress isn’t there anymore.
So my Pico doesn’t have that problem, I charged it long time ago and it works fine. So yours may be defected.
And yes, when charging cable plugged in after finishing charging, battery drains itself quickly, even after 2h with that cable plugged in and a green diode shining, you can unplug it and plug again and it will shine red and charge.
15 lumen is very practical. This is not meant to replace a full size flashlight, it’s just a backup or emergency light. Great for finding the key and door lock hole at night when it’s so dark you can’t see anything. Or in a dark room, 15 lumen makes all the difference. It’s very handy.
True. I was looking for my lost dog today and this High mode was impressively bright, and 15lm for other mode was enough for illuminating path.
This high mode has short runtime of course (so better use it only for a while), but between having this small flashlight or having no flashlight there is obvious choice for me.
So you should consider this flashlight as a “130 and 15lm or nothing”
JasonWW That looks nice too. The Jaxmnve M1 doesn’t seem available anymore although there are some branded differently.
Mocarny Do you have a sense of how long it can hold a charge? Do you think it would make it to one, six, or twelve months?
The quality control with these tiny lights is a bit disappointing and it’s hard to keep track with the number of variants out there. Not too many reviews on them either, which is sad since I think they are the most actually useful EDC in practice because the cost to carrying them is negligible, which as pointed out, means they will be present when needed.
I have no idea how long it should hold a charge, but if it has no defect, I assume it can self drain slowly, like Li-Ion battery, so maybe a year at least. After 2 months of rare use it was still shining well.
Thanks, I would expect a decent battery/flashlight not to drain itself in less than a year. The reports of so many defective units make me hesitate, otherwise I might have already bought it. Your review made it that appealing. :sunglasses:
So I’m lucky to have that working sample. If it’s common problem, I think you don’t need to worry, just ask for refund and provide this comments link, so they can see it is happening more frequently
Mine had the self discharge problem. I noticed about 2 weeks in. I had dropped it once or twice in the following weeks and it continued to work. At 32 days, it died. Amazon wouldn’t deal with it since it was past the 30 day point. Repeated emails to support@lumintop have been ignored. At least I am $15 smarter!
Quite frustrating and disappointing. Out of curiosity, what color was yours? I wonder if there’s any correlation between color and build quality, though I wouldn’t expect it.
