FW3A mod thread. Post yours!
Thanks, that’s exactly what I was going for.
Can you please advise what size of a copper slug is needed?
Have one Novatac, dead, coming my way and i wanted to do the same thing but i have no lathe.
A guy i know has but i need exact measurements... if you could...
Better you strip your head out when you get it, then decide if this is the route you want to go…
There is quite a bit of lathe work the way I did mine… but then I can make different light engines and just swap them in and out… :wink:
Previous post updated. I tried the pencil eraser idea and while it was better than a stock nubbin’ setup, the o-ring really is the trick. What’s needed is pressure to be applied close to the perimeter of the diaphragm switch. This effectively reduces the lever arm/mechanical advantage of the switch, thereby increasing activation pressure. Also, since it’s rubber and not hard plastic, the actuation is also quieter. I’m going to suggest Neal makes these available in his store, or better yet, included in the spare parts bag.
any local SF bay area modder? looking for help on my fw3a. Please pm me. thanks.
So it wasn't just copper pill added...?
Can you shoot me more details and specs in PM?
Take a close look at the pic…driver retainer ring at the bottom, so the head was bored to .900” (to which saves the retainer ring and bezel threads) and the aluminum pill .899” the copper pill was something I had laying around, the aluminum was counter sunk and the back of the pill was stepped and then pressed into the aluminum pill, the whole package push fits into the head and the glass o-ring and bezel press everything together. The original heat sink wouldn’t make contact with the back of the FW3A driver….just a different way of and easier for me of doing it as compared to the original design…. you’ll see when you strip yours…
Sorta like a P60 drop in…if you will… :smiley:
Alrighty then...this is going to be challenging!
Woah. I had a few orings available. I dunno exactly how I feel. That is much - much stiffer. I think I would want something a touch softer. That said, I’m going to run this mod in an edc FW3A and see how it goes. Maybe a thin rubber piece in the middle to soften it up. Definitely no accidental activation though! Thanks for the cool tip!
Small update. I added a couple layers of glow sticker punched to 3/16” for a thin shim. This softens the feel just a touch. Now it’s firm and is unlikely to activate accidentally but not too firm. Love it. I think I can edc this now much more comfortably without lockout.
I’ve ran it both ways and also prefer it with a center spacer, though the difference for me is minimal. I’ve been pocketing this light nearly everyday since I’ve made this mod and seriously can’t remember any incidents of accidental activation. I’d be surprised if your experience is any different.
Glad it worked out for you. :beer:
Great great suggestion!
Thank you, Jared!
I’d gotten used to doing lockouts on my FW3A. It’s pretty easy to do… but sometimes I forget. I decided to give your o-ring swap-in a try, as I have a mini o-ring kit that has a 3/16” ID sized one. I hadn’t taken out the nubbin before… so small. So easy to lose. Mine was in pretty tightly though. Anyway, I substituted the o-ring and wow, what a difference. The button is really tight now. Can’t activate from angled press. The only downside is that the click sound is like 3 times as loud now. It’ll take some time to get used to it. But the implicit safeguard for stopping accidental activation seems worth it. :+1:
EDIT: OK, I went for a day with the 3/16th ID o-ring and decided it was too firm. I stepped down to a 5/32nd o-ring. NOW, we’re talking. This is better. Still tight enough to prevent accidental activation, but requires less pressure & it’s about 30% quieter than with the 3/16th ID.
I’m glad others are finding this helpful! For me, if it weren’t for figuring out a solution to the accidental activation, I would have gave up carrying the fw3a as my edc.
It should be noted that I have very large hands and strong fingers. I often don’t keep that in consideration. The 3/16” o-ring w/o a center spacer is “stiff” in my book. For others, it may be unbearably so. Both of you have built upon the concept and adapted it to your taste, so good work to y’all as well. I’m happy there is a tune-able and simple solution to a problem that can be a deal breaker to an otherwise great design.
As for the noise level of the switch, I’ve had very mixed - almost random - results during experimentation. The smallest tweak sometimes will take it from nearly silent to very loud. :question:
:heart_eyes:
SS bezel and deep carry clip bought from Neal at nealsgadgets.com :wink:
GITD gasket bought from CRX :wink:
Nice one MascaratumB :+1: Looks like it’ll get some use.
Thanks :wink:
Yes it will! I love it! I guess this is one of the things I’ve been looking for for a while now!
BTW, I didn’t think I would like the SS bezel so much, but it looks great :wink:
And the double sized deep carry clip is great! I’ve been carrying it in a “cargo” pants side pocket with the bezel up and it is great!!!
Another thing…The FW3A is even smaller than the D4 (1st batch) :o Love these small powerhouses :crown:
I have an interesting anecdote. When I did the oring mod to my early aluminum FW3A, it was super stiff and I needed to add a spacer to soften the feel. When I did the same mod to my FW3T, it made the switch a bit stiffer and more consistent, but definitely not super stiff at all. Not as edc secure (ie prevention of accidental activation) but much better than stock.
I’ve improved the deep carry clip a bit, it’s perfect now. It is a pity that underneath is a copper color :smiley:
Metal accessories do not react to iron chloride, the bezel only got interesting pits:
