Ok, picking up the pace... looks like we will have Christmas lightening sooner than my wife could expect...LOOOOL
I’m getting a lot of confusion from sunlikelamp.com. I said yes to translation in Google chrome, selected the British flag, and no luck. Here’s a screenshot of what I see. It seems I was able to select both 3000k and 4000k at the same time, as well as the SOL and SAW models at the same time. See pic. And what is the meaning of the letter on the end of the model? For example, SunLike6, SunLike6D, SunLike10X, SunLike6 Bronse, SunLike12D, SunLike12S?
How’s the mod-ability of these sun-like lamps? I want to try some of the 35 volt 90 CRI 2200K COB chips from mouser.
Let me explain it to you.
Yes, you can choose some mutually exclusive parameters. But also you can not choose anything, it is not neccesarry. Anyway I will send payment bill manually.
About letter on the end. What is it mean was in the rus language in price
Bronse - it was 2 years ago, I delete it, but in english version it can be as I see. I just fix it in 6w model. It mean how much leds will in lamp, for example in 12w led bulb can be 25w led, it will more effective.
6 - wattage. It is real, not fake like chinawatts
- bigger body
d - dimmable
x - eXperimental (tried to do cheaper)
s - switchable spectrums
for example on lamptest was 12D Titanium (platinum)
d - China sunlike (SOL)
D - Seoulsemico (SAW)
Now more leds is marked like 13D+ or 13D. Only on bodies.
this was 2 years ago. see model: 12D titan. it is w/o cover (diffuser) and with it
100lm per 1w from the line. 15% take off cover (diffuser)
First, congratulations Adam, you have the post #100 of this thread :)
Can you please add links pointing to those pictures instead of putting all them directly in the thread? I think you should also add explanations with each image, so everyone can understand their purposes and seek/analyse the relevant information in each.
All that will greatly enhance the readability of this thread and the visibility of your posts.
You are also welcome to create a dedicated "seller thread" in the "Commercial Sellers' Spot" section of BLF. You can find information about that in the Commercial dedicated FAQ. You can also ask an admin for further information, if needed. This way you will be able to expose all your products, giving all explanations and pictures as much as you wish.
Thanks Adam. That D,X,S explanation really cleared things up. And so did the fact that you don’t need to make choices in conflicting categories.
One last question, I noticed now that the specs don’t say what voltage they work with, just that they are E27 bases. This makes me think they might not work at all in the USA with our 120v lighting fixtures. Do they work on 120v?
Sunlike, so all of these are + duv? I’m looking for some - duv lights for more rosy tint.
Hi Sunlike, my slavic brother . I suppose Mordor means Russia? I am very interested in the following LEDs:
COB SSC Sunlike
3030 SSC Sunlike
And really need to put them in my products (test series) and propably send some samples to Maukka What CCTs would be most desired? 3000K, 4000K or maybe 5000K?
I use 85-277v led drivers.
But when I add reusable fuse, I marked it like 220v on the body. If for USA, I add 2 times bigger fuse and marked it 110v
it is Qihan. dimmable marked 185-277, but I use it for 34-36v output only while it can give 65-68v, so it can work with 95-277v or lower voltage
I just added voltage option on web-site
MORDOR is territory what was CCCP, because there is a lot of orcs =)
I already done led lamp for Maukka. It is awesome.
3030 sunlike (new 6v) I will use too. I already draw pcb board for it 22x22mm 2S3P
Yes, Qihan produces good quality LED power supplies (I also use them in some projects), but selling to the EU market you should also think about adding LC filters at the AC input (Qihan has also CE certified power supplies with filters but unfortunately much more expensive).
you mean violet spectrum? Yes, it is all with violet. But I also bought some SOLs w\o violed spectrum for lamps for nail extension jobs, because some gels can polymerize in some situations with violet spectrum.
Also who manufacturin SOLs leds do leds for plants, I am going to do bulbs for additional light for plants. Spectrum is like sunlike + UV + IR
That reminds of something I have to say
Guys, I'm pleased to announce I successfully arranged some shipments that are already travelling as we speak. So we'll have in the coming weeks new results from tests:
- Lightning Arena has sent some of their CRI97+ bulbs
- SunLikeLamp has sent a very interesting multi-emitter bulb
Thanks to all parties involved! Both reviews will be carried out by our dear maukka. Stay tuned!
CE from qihan not so good. Low power have no models with voltage and current what I need, 20w CE flashing more than 20% because they have PF: 1
I added supressor and reusable fuse and thermistor. Its enough.
About CCTs.
The most popular is 4000k, I also use it. Another is 5000k (2-3 times lower) and 3000k (2-3 times lower than 5k)
it is completely upgraded v 1.3 and 1.4
it was v.1.2 upgrade
Sorry, I will answer here. I will not create topics yet. Now loaded with work and household chores.
I found the 2800K version of this from a Finnish online store and will report back when I get it. The manufacturer told me that this bulb is about to be discontinued though and I couldn’t find the 4000K version for sale anymore.
Heavily modified Qihan drivers I guess.
Supressor? Fuse? Thermistor?
I added input capacitance to a bunch of Qihan units I had lying around after reading a report of high mains output ripple by some fellow from Mordor or thereabouts, :-)) too. This is a QH-40W-LP with 3 × 15µF (cheap) capacitors:
Let me also share a photo of a 20W “Dark Energy” driver I bought from eBay, which came with good input capacitance:
The above unit had no components on the underside. And I couldn't find sense resistors above either, my guess is they are under the transformer.
It is good 20w led driver. I used it 4-5 years ago in lamps for plants. 25P model. But 600mA disappeared from sale. After that I moved to 20w led driver from Qihan =>22P
About ripple.
There is 2 types of led drivers from Qihan. 1st have no ripple (pulse) in out. This type only 5-20W
2nd is led drivers with good power factor (~0.97). There is only one way do do it not ripple - add capacitors in out.
I tryed to add big capacitors 400v - it was some fatal errors.
The good news, that 80 and 100w models strobe only on 7% (100w 35v)
I mean this
But I also upgrade it to this (old version of upgrade - 1.2)
Where are you guys finding these very handy looking Qihan drivers? eBay and AliExpress didn’t return results that look right.
