No actually I don’t prefer violet spectrum for my needs as I’ve tried a few. I’m only looking for some to replace my current household lightbulbs for nighttime use. I prefer 2700K with a negative duv or below the Black Body Locus tint. I’ve tested many bulbs in the past and only the GE Reveal offers this combo but they keep burning out. Their reliability is the worst I’ve ever seen.
Wow that is some massive output capacitance! Am I seeing the driver came with 8.8mF (4 × 2.2mF), and you added 3 × 6.8mF = 20.4mF to fix the ripple? LoL!
What's wrong with adding high voltage input capacitors, the power factor goes down?
What he means by Duv is “Delta uv”, or the distance the CIE coordinates are from the Black Body Locus. You likely have never been asked that before, but on BLF it’s a huge deal to many users. Above the BBL is a greenish tint, that disgusts some people. And below the BBL is a reddish “Rosy” tint.
For me, a “rosy” Duv isn’t any better or worse than a “greenish” Duv. But some people need rosy.
This is about as green as the sun. But from other threads I know some members consider that unbearably green.
Heck, another member mentioned about a month ago they were trying to get the BBL standard lowered because they thought they had research supporting their claim the BBL itself was greenish. But that research seemed to be using “Fake White” RGB lighting.
I hardly doubt it is a galvanic isolated driver (propably some kind of flyback topology) so in this circuit this inductive component works more like coil/inductor not transformer.
No, I can not wait! I just send this lamp today. World must know this thing (190g weight)
2700/3200/5000/5600/2700+3200/5000+5600/2700+5000/2700+5600
/3200+5000/3200+5600/2700+3200+5000/2700+3200+5600
/5000+5600+2700/5000+5600+3200/2700+3200+5000+5600k SunLike10xss
It can be my last lamp. I am going to escape from the MORDOR. I just get passports.
I saw on post #107, Adam, your PCB layout was marked “CCCP”. At least in the USA, and especially the generations older than me, that can trigger political feelings. I wouldn’t recommend it for the next batch of PCBs. Sorry.
But on a happier note, I was wondering where you were escaping to? I assume it’s a vacation destination?
I'm not sure I understand what you're trying to say.
Will the drivers have problems? Because I added 4 × 15µF to a Qihan 1500mA output driver and its working fine, many weeks already.
Using some simple linear power supply calculator looks like the power factor for the QH-40W-LP driver I posted above, when loaded with ≈24W, as a rough estimate drops to 65%. Just rough guesstimation, of course.
Capacity 60uF is a small value for LED driver of this power. Adding capacity to output usually, except smoothing output current and changing PF (to one side or another), generates also greater current surges when switching on, unless there is a soft start (e.g. NTC thermistor). Current surges if you overdo with the additional C may cause a fuse activation or damage the rectifier bridge, etc.
Adam, what is your emigration direction? Maybe Ithilien? Come, we will establish a global corporation producing the highest quality LED bulbs :smiling_imp: .
Joshk
I’ve lived in a socialist country for almost ten years of my life. Thanks to this “brilliant” political system that the Soviet Union has funded in this part of Europe, we are still economically backward and poorer than western countries, So I also do not like the CCCP mark on the PCB layout.
