I flashed the latest firmware and… it’s not fun. Getting everything out and back in again is pretty painful. Ah well.
Could someone please measure the diameter of the optic and/or MCPCB of the MF01 mini? The internal diameter of the bezel would be helpful as well.
Mine also like that, I haven’t got around to test it yet - too buisy buying stuff and bad health
I don’t want to unscrew the flashlight again so I will give you the dimensions of glass instead inner diameter of bezel (all dimensions are approximately ± 0,2mm)
Glass - 40mm x 2mm
MCPCB - 32mm x 2mm
Optic - 34,75-34,85mm x 9mm
Thank you very much, Chatika vas Paus. These are exactly the data I have been looking for. Your fotos are excellent and give a good overview of the internals.
My thermal paste was also a bit iffy, so I’ve replaced it:
Interested thanks
I remeasured using a high drain Golisi 4300mah cell and got 3,860 lumens at turn on compared to 3,770 with the Vapcell 26650. Meaning the SST-20 4000K is pretty much pushed to the max already even with the Vapcell 5500mah.
You think it’s maxed due to the led forward voltage and not anything related to the driver or battery circuit limiting output? This distinction is something I’m trying to figure out. It’s a bit confusing.
PS, it’s also good to record beyond 1s, like to 10 and 20 seconds for instance just to see how quickly and how low the output drops due to the battery load and leds heating up.
First 5 minutes of turbo, two batteries compared:
Which Keeppower?
Whoops, should have specified.
Nothing special, but it’s damn hard to get 26650s in AU.
Okay, the 5200mah are the older, weak ones. This explains the giant difference you saw.
Yeah, I’d love to get one of those Shockli 26650s, but nigh-on impossible to get here.
sigh
I found out that the LVP goes by the same voltage it blinks out (the MCU blinks the voltage it sees and LVP is controlled by the MCU). So if the voltage reads a bit lower than actual, LVP will activate a bit sooner.
I dont think there is much in the way of fixing the thermal stepdown behavior. On some driver designs the stepdown works well and on others it acts not so great.
Has anyone tried setting the top of the ramp a tiny bit higher or lower and then checked how the thermal stepdown responds? Maybe it will change.
They are also sold as Vapcell 5500 and Keeppower 5500/6000. Have you tried a search for those? I guess it just depends on whether any stores in your country are importing them. Theoretically, if one of your stores can get the older Keeppower 5200, they may also be able to get the newer 5500/6000.
I just got the full copper version today and took these measurements using Golisi 4300mah batteries:
Copper SST-20 4000K Max Output (stock lens)
Output: 4,181 lumens
CCT: 4019
DUV: –0.0009
Ra (CRI): 96.5
R9: 86.9
R12: 83.0
Rf: 94
Rg: 101
Copper SST-20 4000K Max Output (UCL lens)
Output: 4,362 lumens
CCT: 4028K
DUV: –0.0019
Ra (CRI): 96.7
R9: 89.2
R12: 84.1
Rf: 94
Rg: 102
EDIT: Updated test with Vapcell 26650 4200mah, Copper SST-20 4000K Max Output (UCL lens): 4410 lumens and 4,480 lumens
I’m surprised the copper version is so much brighter than my silver aluminum version. Also the cct is cooler and the tint is much better (less green). I wonder if Lumintop used the FA3 tint bin in the copper version and the FD2 tint bin in the aluminum version. TA said Lumintop was able to buy about 1,000 of the FA3 tint bin emitters and the rest were the FD2 tint bins.
I wonder if the brighter output is due to a better emitter bin or is it because copper conducts better. I tested swapping the copper and aluminum tubes in both lights and didn’t see any change in output in both lights so at least we know copper tube will not increase output.
Despite measuring brighter, the copper version actually doesn’t look as bright on the wall because the hotspot is noticeably less defined as if it is shined through a diffused optic. The aluminum one has an obvious circular hotspot, with the hotspot yellower than the spill. The copper version hotspot tint and spill tint is the same so maybe that’s why I don’t see a defined hotspot but it’s strange since the emitter is the same SST-20 under the same optic. The more negative DUV of the copper version really makes things look nicer, cleaner, and more neutral white. I’m a fan of very warm temps but not yellow tint (+DUV), so to me I like the copper version beam color much more than the aluminum version.
Btw, the Golisi 4300mah produces 13% higher output compared to the Shockli/Vapcell 5500mah. However, Golisi 4300mah measures about 4,200mah whereas Shockli/Vapcell 5500mah measures about 6,000mah.
FET driver lights are not known for their consistency.
I guess you are right since I see variations between E07 also. However the two MF01s that I have measured the same output.
