This is a beautiful light with great mode spacing! So I just purchased one in warm tint - with $3.95 flat rate shipping. Love that it is a twisty and only 67.4 mm in length. Thanks!
Edited:
FWIW, an extra 20% off the $20 sale price is available with code 20%. Ships to UK. France. Spain. USA. Canada. Germany. Italy. Japan. China. European 23 countries. Free shipping is available at least for US customers, but I don't know the threshold.
The 219c is no worse than the stock emitters; I very much prefer it over the cree rainbow.
As for 6500k Osram it makes blue objects look really good, but not anything else.
My current rotation is Thrunite Ti3 (with 219b SW45k) and C01 3500k; not available to buy.
Thrunite has lowest low mode but the stock emitter is ugly. If tint and cri is a priority than any of the Lumintops that have Nichia or the C01S SST20. The size of C01S is not much bigger than most AAA keychains lights, it has a well thought form factor.
My daughter needed a keyring flashlight and I gave her my long-serving and well-loved Thrunite Ti. I can’t think of anything better anywhere near the price point.
I took the opportunity to upgrade to a Prometheus Beta QR and I love it. It’s spendy but looks and feels great, not to mention having a great beam and tint.
The original NW XPL is a very pleasant tint but a very poor CRI. Luckily, if its your thing, its VERY easy to remove the pill to flow your choice of emitters to the star. Now what is interesting is that the star they use does have holes drilled into it for mounting the optic. I chose to reflow a XPL warm 80cri emitter instead of trimming the optic but you could probably do that as well.
Just got a second one as I sent the first one back because it has next mode memory which I disliked. I just assumed it would default to FF. Ended up getting another because I really liked the light itself. What a crazy UI.
The Lumitop EDC01 is my favorite AAA light with the Fenix E05 a close second. Both are small and light-weight making good for keychain or small emergency tin. The EDC01 beats out the Fenix imho because of the higher max lumen and better mode spacing between M-L.
Not mine. It always goes to the next level. Turn off in medium, turns on in high. Doesn’t matter how long it is off. Won’t turn on in FF unless you turn off in high.
for the OP,
i got this “Enjoydeal” wonder for $1 in an order from BG, and it’s a bright little light and most useful EDC. It has a belt clip that i use on a hat brim that is especially useful at night if you have to check something under the hood. It has holes in the tail for adding a lanyard or keyring hoop. i filed a notch in the rim to provide some light when head standing. Simple On-Off tail switch but runs forever on a AAA. Wish i had a dozen to pass out to friends it is a great light.
no I am guessing. It's the same as the nitefox k3 driver, the hardware is exactly the same and I remember someone measuring around that much for the k3. I swapped the pills inside both, I have an LH351B 3000k inside mine and it's wonderful. Not too bright at night at all because of its warmth. Amazon review mentioned 3lm and I believe it,m ed they said was 25lm, and high is 120, all are very much in range of my usage
I am sure it's not sub lumen though. 100% sure on that, it was much too bright.
Is it a 219B or 219C? If I scroll down and look at Features, it says:
Features: -NICHIA 90 CRI NVSW219C-R9050-SW40 LED
-Orange Peel reflector
-Head rotary switch
-Aerospace grade aluminum body
-Mil-Standard type III hard anodize
Package inlcuded:
1 X Astrolux A01* Nichia 219B 102LM LED* Flashlight
1 X O-ring
It probably used to be a 219b that they downgraded to a 219c - and they are trying to obscure this fact. They may feel covered as long as 219C is stated somewhere in the description page, even though 219b is stated in at least three other places. Bummer, and sorry.
