Hi guys I wanted to address the most common issues with this light and some solutions I found, but I decided not to spam freemes thread so much so I made a new one for technical issues with this light:
Its based on info I got from Lexel and ToyKeeper. It adresses thinks like LVP, incorrect voltage measurement and the light throttling down from max ramp.
Tint on the 4000K is worse than I expected. Now I’m torn between trying to lower the DUV by swapping three leds to 2700K SST-20’s or swapping all to 4000K SW40 219B’s.
The target would be to get a acceptable (= zero duv or below) 200lm mode. I see the 2700K is in the BBL at that power, but the FD2 quite high above it.
Actually I don’t like rosiness at 4000K but prefer a neutral- slightly rosy tint.
From my experience 4000K on the BBL is a little yellowish for my liking. 4000K at DUV –0.002 looks much more neutral. 4000K with DUV of –0.003 to –0.004 for me seems perfect neutral white because I don’t see any yellow or pink unless I compare it side by side with another light of different tint. Maybe it’s my eyes or the ambient environment I’m in.
Does anyone know how to turn the secondary brighter? On mine they are so dim I can barely see that they are on. I took the bezel off and looked at the pots but I don’t see how to adjust them, looks like a cage covers them preventing them from being adjusted.
Set them to High in the software settings first. Seven fast clicks from Off will cycle them Off, Low, High, Blinking. If the High setting is not bright enough, then you can try turning the pots. You need a small screwdriver.
Here is a pic of the MF01S.
There is no cage. If yours has a cage, can you post a picture?
