I agree. Looking forward to you and other testing it.
To the best of my knowledge and based on output,The life of a Golisi on max[increments of 5 min.] will not be much more than my buddies MT35 W/XHP 50.2. Turn on was 4100L
5 minutes-3.83V
10 minutes-3.62V
It drains the battery as to be expected. That is why I have 3 X Golisi and 4 X Aspire. :sunglasses:
I got a modded triple XHP50.2 3V light that hit over 30 amps off a fresh GOLISI, so high amps draw is fine with me. The main thing is how this light does on throw, compared to the 220 kcd rating. It's the simplest thing to measure, in fact I find it wayyy easier than doing beamshots, though results may and will vary. I got 3 light meters and they have about a 5% variance range.
This SBT90.2 sure looks like it beats the dedomed XHP50.2 and the dedomed SST40 in throw, and of course much higher in lumens. Not sure where it is head to head with a XHP35 HI in throw, but the XHP35's require a special driver because of the 12V and restricted amps.
As far as I’m aware the XHP35 HI doesn’t throw as well as the SST40 but it’s pretty close. Besides having a slightly smaller head the Acebeam K75 is around 40-50% more intense than the BLF GT/Astrolux MF04. Acebeam T27 XHP35 with its 70mm head does 340kcd and the FT03 (same head size) does 367kcd with a Dedomed SST40. Obviously everyone’s measurement are a bit different but it does seem like the SST40 outthrows it by a bit and the SBT90 outthrows them both. According to that Chinese video though the SBT90 intensity was slightly less than the SST40. Even when comparing bluzies pics it seems pretty close to FT03 and a bit behind the M3XS-UT (250Kcd). Doesn’t make sense to me though. The SBT90.2 should be outthrowing the SST40. Hope that made sense. Lights are shipping soon so I guess we’ll just have to wait for some proper tests.
I assume you mean the SST40 DD, not the factory SST40 with dome. Things are getting a bit strange now, since I assume the SST40 is only produced with a dome, but we can buy dedomed variants, but I have to assume the DD is done after market, not by the factory, so there's no protective film/covering over the phosphor I guess?
Not so long ago, the XHP35 HI was the best factory LED available for throw, but clearly the OSRAM's 1mm and 2mm factory domeless throwers should have everyone beat, but at a cost of low amps, low total lumens output, and having a tight pencil beam. I haven't been sure how the SST40 DD fits in, comparatively, but glad you provided that info above. Of course it can be driven hard with decent lumens output and it's large surface should have a decent width beam. The newer XPL HI V4 bin LED's should also be competitive I would think, but again, not sure where it is in direct comparisons, but with the XPL HI's, all depends how many amps you can get out of one.
tm07 dedomed his FT03 and it went from 235kcd to 367kcd. Someone else said his was 357kcd. Unfortunately they are not available without a dome. Hopefully Luminus decides to make some. Could make some really good budget throwers.
Neal lists a bunch of comparative throw #'s of the LED variants for this Nightwatch NI40 Stalker here, which is pretty useful info if it's correct, and if it is using a true FET based driver as I suspect it does, based on the power(W) numbers listed.
He said he’ll receive them this week and they’ll also ship the same week. Mine hasn’t shipped yet though. Someone above said the stock is supposed to arrive on Monday which is 3 days ago. I did message him yesterday asking if I’ll receive a tracking number when it’s shipped to which he said yes. Tried emailing him a few days ago. Didn’t work. I only message him on FB now. Sometimes he doesn’t reply but these last few days he’s been replying pretty quickly.
Low performance of GT mini in my case is probably caused by springs, because sometimes I use longer cells with integrated charging in GT mini. The measurement was taken with VC6 and it resulted with reduced springs tension.
I am glad that it shipped. However, almost 1 month [initial email, sent Two]with UNANSWERED questions is UNACCEPTABLE. The questions had nothing to do with shipment, it was a question about conflicting information regarding step down listed on his website and what a user experienced.
If he was a dealer in USA he would be out of business! I am not alone in the frustration regarding his inability to respond to his customers. We should not have to chase him on FB or wherever else he can be contacted.
I hope the light never has an issue. If so, I expect nothing after this experience.
I don’t know why I’m ordering from Neal as the last order was a PL47G2 from him and I waited 38 days for it (to just be shipped) and it came w/ massive problems (like the head/optics being misaligned, and the rubber o-ring falling into middle of the optic and sticking there, causing beam artifacts. Sounds like he picked out the factory-seconds and mailed those out. I guess I really wanted a SB90.2 light. But now the FT03 is gonna come out w/ a SB90.2 light I might just cancel and wait for that.
How do you enter the turbo on NI40 with SBT90.2?? Instructions says double click. I have been messing with it for 15 minutes and still can’t figure out from which mode double click turns on the turbo. Was able to access it a few times though
Does anyone know?
