2200K would be really something .
It is fine if it will not happen right away. To fill an interest list takes at a month or more so no hurry. For an interest list to work I do need a price indication and which led(s) we are trying to get.
Thank you sooo much for these! I got my order last week of 100 3400K and have slowly been sprinkling the joy of warm HI CRI LED light 10 lumens at a time. Just doing button cell keychain, an old 2AAA medical light… and such so far. I have a couple 12 and 30 LED projects in the works to use up half the stash already.
….so I just ordered another 100 3400K. Not to hoard them, I just never want to run out! They seem to be finding homes rather quickly just turning craptastic little lights into fantastic.
For now I’ve changed some of my LED candles out to the 3400K 5mm LEDs modded with a Rosco Cinegel #3407 orange filter in front. The high CRI really compliments the professional filter, and the color is amazing. I will try to take some comparison shots between original (monochrome orange LED), modded, and modded with filter. I’m currently away from home so I’ll be doing some mods next week.
new batch of T/N:
calipsoii - LX104000074TH
LowLumen - LX104000088TH (2x 3400k)
Scientist - UA121600039TH (1x 5800k)
djozz - UA042104465TH (2x 2300k)
Unheard - UA042104474TH (1x 2300k)
Skuzapo - LX054011240TH (1x 2300k)
id30209 - RR278750245TH (1x 2300k)
Nismo - RR278750254TH (2x 2300k)
khas - RO247700275TH (2x 2300k)
cetary - UA121600073TH (1x 2300k, 1x 3400k)
OtisCampbell - LX104000091TH (1x 2300k, 1x 3400k, 1x 5800k)
*T/N number beginning with ‘U’ is non-trackable online. Contact local post office for status after 1-3 weeks.
That led seems bi-colored. There seems to be two cathode leads.
If that is the case, you might have to deal with the different positioning of the anode lead.
Hardest part would probably be to make reliable contact to the shell. Othewise it is just plastic work. You’ll probably need epoxy. Brass pin should be soldered.
Guess what arrived?
@5500k WB
@2800k WB
Wonderful and unique, I have never seen 5mm leds in this tint and CRI , I’m in for a batch! (100?)
Me too.
I’m also in for 100 of these 2800K 2300K ones! Looks absolutely gorgeous.
This is 2300k though. “2800k” is just the WB setting.
Oh my bad, I read 2800K trough the glare on the photo. 2300K is even better, then!
I.e., a panel of 30 LEDs with some degree of tint control. That’s my plan. Housing done with my 3D-printer. My desktop is to be illuminated.
Gotta be careful with the current though. This batch of 2300k LEDs has 0.1v less forward voltage than the other two tints and also (supposedly?) 45 deg angle rather than 60 degs.
Will do a quick voltage/output test when my batch arrives, and post about it here.
Hope the tint is below the bbl or it will look too yellow at that tint. If so, I’m in.
In for 1 pack of turbo warm 5mm
In for a pack of the 2300k
