I have started liking the 'Tactical flashlights" idea not so long ago. It was only after I got my hands on some 'real' tactical lights, not the ones eBay listings call 'tactical'.
When I'm out in the field doing beamshots I like having a flashlight that will produce X with 1 click on a button. A Anduril UI or anything similar doesn't belong in a tactical flashlight.
For me, a tactical flashlight has a UI you don't need to remember! The UI should be self explanatory without hidden modes, multiple clicks.
1 click for ON (high/turbo)
if possible 1 click to Strobe.
UI should go from High mode to low mode, not vise versa, unlike and EDC light.
That’s why a “tactical knife” like a Ka-Bar doesn’t have a bottle-opener or other nonsense attached to it. It does one thing but it does it flawlessly.
Anyone who wants a SAK can certainly get one, and they’re quite handy (just ask MacGyver), but it won’t be “tactical”.
I’m not convinced a dual sleeve design is a good idea for a light designed to handle constant repeated impacts / recoil. Also onboard charging will be a real pain to get potted properly to stand up to the same abuse.
That’s how I have my Quark Smart QSL set up too and I like it a lot (side switch turns on, off, and changes brightness…with blinky modes disabled; and the rear switch is full power momentary only).
Thank you all for your valuable feedback so far. I have designed a new draft design that hopefully reflect most of your input. I also drafted a basic dual switch UI for this flashlight, see OP on this thread. Please feel free to comment on this new design. Thank you!
The spot you found for the USB port is challenging. The socket is where the battery tube threads into the head. Unless the head and battery tube is one piece but that requires an unconventional method to assemble the driver.
I have the BLF D80v2 and like it a lot.
I wish you all the best to Jackie and the team, my very small contribution will have to be the purchase of the final product since I`m a newbie on the subject.
Thank you all in advance for your hard work.
I recognised where it came from , and I really like the F1 USB solution, and now I started wondering how it was done. It took a blowtorch and some force to find where the head/battery tube joint was:
So they extended the head part a bit compared to other tube flashlights, and the driver sits lower,to make room for the USB socket. Which adds 8mm length to the F1 exclusively for the USB port which is not really needed. The cavity from driver to ledshelf is a whopping 22mm, they really made no effort to make the F1 compact.
Some ideas. Don’t worry about that magic 25.4mm/1” body tube, add some more metal and bring it up. Very rarely are flashlights mounted anymore, 1” rings shouldn’t be a limiting factor. Head shouldn’t be too much bigger than the body. My large belt light has a 30mm body, 37mm head, 143mm length. Bigger heads on belt holsters can chew up shirts and car seats. I still use tail standing for buildings without power. Recessed tail switch help stop accidentally turning on the light. Steel bezel with minor ridges.
Thanks a lot for investigating how the F1 is constructed, Djozz!
I extended the head part a bit to reflect the additional space for the cavity the battery tube's thread section needs to fill before its front face touches the driver's rim, see brown highlighted part below.
I am very interested.
Don’t need the charging port.
I assume it adds costs and complexity to the design
I assume no one is completely happy at the end
Micro USB or USB C
1,2,3,… Ampere
USB, USB QC, USB PD,…
Really fully sealed,…
Maybe it’s easier to point (alongside the battery recommendations) to some cost effective decent single battery charger for people without charger.
I assume that people having chargers, but none that supports 21700, will sooner or later end up buying one anyway. And then with all the nice choices on the market.
