FW4A (quad emitter, similar Performance to D4, 18350/500/650 tubes compatible)
Interested! (Just had a look on your Instagram)
Also interested
Interested
Edit: Deleted the pics now that Martin has them in the first post.
The head on the angle light is too bulky. Triple TIRs are very thin, but this looks like it adopted the Fireflies design of having the battery extend into the head instead of being shaped like a Zebralight H600 series, etc….
Interested
I would be interested in the quad! I am really waiting for a 21700 single with a reflector that is slightly larger diameter at the same or greater depth.
Interested
Is that a screw-in bezel on the HL3A? Does it have the same driver and firmware as the FW3A?
I think the whole head is different
I’m not very focused on if it is 3 Leds or 4 Leds. If 4 Leds give better efficiency with higher sustained output with less heat then yes, else I see no point.
Is that a Carclo or Lumintop sourced Quad optic?
I really don’t want to be “that guy,” but I’m going to be I guess.
About the FW4A… WHY?
With the exception of the FW1A and materials choice on the original, all of these off-shoots have been really half baked IMO. The 21700 version for example…
The question (for me) isn’t whether or not anyone will buy/want one, but is there a meaningful differentiation in performance or design to justify it? A single 18650 triple in an air-weight body is already pushing practical design limits. Upping it to a quad w/o at least moving to a 21700 just doesn’t make any functional sense to me.
So I’d say for a decent design, that at least has a chance of raising reasonable interest here, take this quad head and put it on the 21700 body. MAYBE then.
As for the headlamp, the design again just doesn’t inspire any sense of uniqueness, aesthetics, nor original thought.
I apologize for the word vomit here. I’m sure I’m not the only one thinking it though.
The headlamp is bland and boring but I’d probably get one if it has the same guts as the FW3A and a screw-in bezel. If it has a different driver and isn’t running Anduril then it shouldn’t have that name.
Completely agree about the FW4A.
I’d love a single LED version of the HL3A.
Interested.
Interested
interested in both
Interested in the headlamp.
