BLF Lantern Purchase/Followup Information - Group Buy list is Closed!!!!
I hope this USB flap breakage doesn’t happen with the one I’ve bought. It’s going to be a gift, and that would be embarrassing. :weary:
If the cover’s off and the lantern gets hot can’t condensation build up inside?
We have mentioned the issue about the USB-C cover flap, with some having them break or loose them, hopefully they can rectify the problem with them breaking.
When I charge my LT I pull the cover off a bit and then rotate it out of the way in order to plug in the connector rather than pulling it up and out of the way. I have no evidence to back it up but my feeling is that it places less stress on the the part that attaches to the LT.
Thanks for the help guys. I just sent a message to Barry/Sofirn as MtnDon had suggested and he got back very promptly to send out a couple of spares, fantastic service.
I have several of the first 500 reserved… yet still haven’t been able to order a single unit. Hopefully all of us who have followed this project from the beginning will have a chance to receive all the lanterns we’ve preordered.
Got my code today via PM but it said to message back if I needed a code that included batteries. I did just that and have not been sent my new code.
Time difference between “there” and VA ???
They are somewhere around 13 hours ahead of EST.
Expect that they’ll send you email while you’re sleeping and you’ll reply while they’re sleeping.
Same for me, which is why I didn’t make it onto the first order.
How long until they responded to you and provided a code that would also work for a lantern + batteries code?
Same feeling here. I rotate it 180°
They never did.
When was this?
Have you reached out to Lan Lee yet for a resolution?
I responded to Lan Lee’s initial private message (as the Sofirn user) as per the instructions and said I need the code for LT1 + batteries (responded twice). No response. I will now send a new private message.
Button top or flat tops?
Part of your question is missing.
If you’re asking what Sofirn supplies, they’re button tops.
If you’re asking what will work in an LT1, the answer is button tops, but also the ‘extended flat top’ Sanyo GAs. Standard flat tops and flat tops where the positive contact is kind’a tall and comes close to the insulating wrap are a complete No-Go.
I work in IT, and I feel this so much. Having a day of that today, and this comment gave me a smile.
I appreciate that you answered the two most obvious questions they could have been asking, and that you were pretty thorough. This general attitude of helpfulness is part of the reason why I like this community so much.
I would add that a search (and probably the OP) would have also yielded the answers with only a little effort. Everyone should try to find the answer first, then ask after they are unable to find the answer (often, the answers can be found quicker by searching anyway).
I’m thinking the OP needs to be updated to note that batch 2 is now shipping? At least I think that’s true based on this post.
EDIT: opps, I didn’t create this topic and can’t update it)
