Exactly, I pointed out this problem to them on 11/3/19 on Post # 152 before the 2nd batch was sent out.
I have yet to hear a response. In the mean time, I’ve been reading some comments that Neal doesn’t answer his emails.
You need to contact him through FB, but he may or may not reply. I find that a little disturbing.
What’s going to happen if you get a defective unit and you need to get the issue resolved.
If someone doesn’t respond to a inquiry that would lead to a potential sale, I would think it would be a nightmare if you need to make some sort of claim for a replacement or refund.
I agree. For me, I would just take the loss even though I do not want to. It would NOT be worth the frustration in waiting for a response. If he does not answer simple questions from many of us, why would we expect him to respond when a light has an issue?
This is my first experience with a GB with him,and most assuredly my last.
No, he said make “h” dimension bigger (lower case h in that drawing) That is the dimension between the “nubbin” and the bottom of the switch boot- in other words, trim the nubbin in the middle underneath back.
Oh, no worries…In the diagram, upper case H is different than lower case h was all I was saying.
I do hope mine works right…otherwise I’ll be sourcing another driver. I do really like the size if the light- it’s about as big of a jacket pocket light that id want.
I’m driving but. I still have to figure out what needs to be trimmed or made bigger! I guess I’ll try to trim the h dimension . How do I get the rubber button cover out. Just pull out from the end of the light by force? Will I easily be able to put it back in after? Thanks
You will easily find out yourself
But to ease your mind a bit: likely when you look on the inside of the tail section you will see a ring that has two little opposite holes. Stick something in those holes (tweezers or pointy pliers or whatever) and unscrew that ring. Now you can pull the board with switch out and under that you will find the switch cover. Cut a mm off the nubsie ( :party: ) and reverse everything until the tail is whole again.
Thank you
So access the ribbber cover from the inside the light? I was hoping to just pull it out from the outside without having to mess with the ring ugghhh ok. I will report on this results of this operation!
From my experience most tighten clockwise, loosen counter clockwise. However, I have had a few that did the opposite. Simply try loosening it counter clockwise and if seems too tight go the other direction. That is how I had to loosen a few of them. In my opinion, oil is unnecessary, just turning it the right way should work.
I tried the mod and it improves things slightly but the ui is still erratic.
I removed the brass ring with needle point pliers used anti- clockwise. The switch body then drops out with a tap to encourage it. Then the rubber cap can be pushed out. I turned the cap inside out and rubbed about a millimetre off with a sanding block. Reassembly is easy just reverse the above ensuring that the switch assembly is seated correctly. I can now get turbo with a double click but not every time.
Same results here . It doesn’t matter whether the nippple was there ( h dimension) or not. It’s about how the actual switch work ( or doesn’t work) The intended purpose of cutting it down was not to push in the button as deep so it doesn’t make the full click maybe. I sometimes am able to get into turbo by pressing the rubber half way ( twice quickly) before it makes the click. Once I click( double click) I never get the turbo, but your hands have to be so fine tuned, it’s impossible to retain the same amount of force every time. The switch itself is faulty or the design of it is.
And meals site always answered thru the chat while the lights were in transit but not any more, not responding to the chat in the last 12 hrs
Comparison of ni40 with SBT90 gen 2 vs astrolux ft03 with hp50.2 4300 lumens
1. Size: NI40 head is smaller and it’s a bit shorter so 1 points in favor of Ni40
2. Weight :NI 40 is a bit lighter , about the same, or at least the weight is more concentrated in the hand, so 1 point for NI 40
3. FT03 has better UI, ramping , voltage meter, other functions so 1 point for FT03. Plus I don’t like tail bottoms but that’s petsonal. Anyway 1 point for astrolux
4. On turbo ( if you can switch to it) NI40 is slightly throwier than ft03 so 1 point. For NI40. The difference is not that obvious though , I believe the photos may have beeen a bit misleading
5. The faulty switch issue for NI 40to turn on turbo for a number of people is a big minus, so 1 in favor of FT03
6. Price of NI40 is about twice the price of ft03 so 1 point for ft03
7 lumen output about the same, but need to remeasure. I don’t think it reaches 5,000 lumens. It’s a tie for now. Both eat thru the battery pretty fast, output reduces when voltage drops and of course there is some battery sag on both.
8 slightly bigger hot spot for NI but bigger corona for ft03. Corona colors a bit yellowish for ft03 so.lets say it’s a tie
Stilll need to get power consumption.
9. In general brighter spill for ft03 , useful when riding or in general, making this a great combination light with a more balanced ratio between spill and flood- a p0int for ft03
10 on turbo at least NI heats up faster so a point for astrolux
FT03 can reach 5300 Lumens or more. I have a Astrolux EC01 with 3V XHP50.2. And the Lumen rised from 4300 to 5300 at startup with bypassing the springs.
I am waiting for my FT03, but sadly its not shipped yet.
