Delivered Oct 3.
okay wow…… thats just not acceptable at all… zero communication. not sure what to suggest then…. shame u sent it and didnt do a paypal refund instead….
it seems they dont stand behind their lights or honor even warranty like imalent… i have one light that works and doubtful i would buy anymore after i read stuff like this….
I regret not doing that in the first place. I just want the damn thing back so I can send it to Vinh and get a working light back.
How did your E07s die?
I just heard back from Jacky. I will be sending him a video and hopefully he will be checking up on the status of my Copper E07. I will update as this is dealt with.
I don’t know how the Brass died, it had very little use. One morning I woke up and the AUX leds were off, I then trouble-shot it but nothing worked, just a totally dead light.
The Copper had a number of issues. Wrong Aux installed, dead aux lights in switch…. can’t remember the rest honestly I’d have to dig up the old emails.
It’s a Manker MK39.
I found this optic on Alibaba: This product is no longer available.
It seems it would fit the Fireflies E07 and has many different angles to choose. The seller told me they have a MOQ of 500 pieces with 0.27$ per optic. They don’t sell smaller quantities for personal use. I haven’t found this optic anywhere else.
Even if the position of the LEDs is correct, the position of the optics legs isn’t. In the one you showed there are 3 in the middle, and originally there are 4 on the edges in addition, forming a rectangle.
If you look at the drawings and the measurements you see that it actually has four legs. Similar to this one: 35mm 7 In 1 Module Pmma Spotlight Led Lens - Buy Spotlight Led Lens,35mm Spotlight Led Lens,Pmma Spotlight Led Lens Product on Alibaba.com
I bought a used e07 and it has no candle/lighting/temp calibration modes…is this the simplified UI you are talking about?
I tested my two new E07 additions with the Texas Ace Lumen Tube calibrated with Maukka lights and Sekonic C-800-U spectrometer. Lumens taken at 2 seconds.
E07 Copper XP-L HI 5A | Turbo | 7,112 lumens | 4252K | -0.0047 DUV | 72.2 CRI | -17.2 R9 | 45.9 R12 | 67 Rf | 98 Rg | 30T | |
E07 Copper XP-L HI 5A | Mode 7 | 2,397 lumens | 4157K | -0.0041 DUV | 72.1 CRI | -17.6 R9 | 45.6 R12 | 67 Rf | 99 Rg | 30T | |
E07 Copper XP-L HI 5A | Mode 6 | 976 lumens | 4067K | -0.0030 DUV | 72.4 CRI | 30T | |||||
E07 Copper XP-L HI 5A | Mode 5 | 373 lumens | 3956K | -0.0010 DUV | 72.8 CRI | 30T | |||||
E07 Copper XP-L HI 5A | Mode 4 | 171 lumens | 3958K | -0.0010 DUV | 72.8 CRI | 30T | |||||
E07 Copper XP-L HI 5A | Mode 3 | 66 lumens | 3945K | -0.0008 DUV | 72.8 CRI | 30T | |||||
E07 Copper XP-L HI 5A | Mode 2 | 16 lumens | 3947K | -0.0008 DUV | 72.9 CRI | 30T | |||||
E07 Copper XP-L HI 5A | Mode 1 | 3 lumens | 3908K | -0.0004 DUV | 73.0 CRI | 30T | |||||
E07 SST-20 4000K FA3 | Turbo | 4,310 lumens | 4120K | -0.0038 DUV | 95.5 CRI | 86.7 R9 | 84.3 R12 | 92 Rf | 103 Rg | 40T | |
E07 SST-20 4000K FA4 | Mode 7 | 1,750 lumens | 4165K | -0.0010 DUV | 94.4 CRI | 87.4 R9 | 82.0 R12 | 92 Rf | 103 Rg | 40T | |
E07 SST-20 4000K FA5 | Mode 6 | 752 lumens | 4159K | 0.0001 DUV | 96.0 CRI | 40T | |||||
E07 SST-20 4000K FA6 | Mode 5 | 324 lumens | 4055K | 0.0006 DUV | 97.8 CRI | 40T | |||||
E07 SST-20 4000K FA7 | Mode 4 | 148 lumens | 4045K | 0.0004 DUV | 97.8 CRI | 40T | |||||
E07 SST-20 4000K FA8 | Mode 3 | 58 lumens | 4058K | 0.0003 DUV | 97.8 CRI | 40T | |||||
E07 SST-20 4000K FA9 | Mode 2 | 14 lumens | 4072K | 0.0001 DUV | 97.4 CRI | 40T | |||||
E07 SST-20 4000K FA10 | Mode 1 | 3 lumens | 4076K | -0.0001 DUV | 97.0 CRI | 40T |
The FA3 tint bin is the rosiest SST-20 4000K I've seen to date and I've seen MANY! It's better looking than the FD2 in the FW3A, FB4 in the Emisars, FD2 in the Mateminco/Astrolux, FB4 in the Acebeams but it is still nowhere as rosy as the XP-L HI 5A tint, which is perfection. The copper E07 is gorgeous! It's a must own for any flashaholic! Goes really well with the Red Aux light IMO. Also this time around UCL lens didn't improve the tint much. Only dropped DUV by about -0.0003 to -0.0004, which is not noticeable at all. The UCL lens improved tint much more in the older E07 batches. I guess the lens used in the recent batches are improved from the older batches.
Edit: I just realized that the optic used in my latest two E07 is narrower throw than the optic used in the older E07. Comparing my new E07 SST-20 with older E07 SST-20 and comparing my new E07 XP-L HI with older E07 XP-L HI, it is very obvious that the hotspots from the newer E07 are smaller compared to the hotspots of the older batch of E07 using the same emitter. However, I cannot tell a visual difference in the optics.
So my (new to me, bought used) e07 has crushed the top of my Sofirn 21700…was there any resolution to fixing this issue? As far as i can tell, my version is one of the newer models…
I thought the newer versions was made longer to accept the longer 21700 ? guess not unless for some reason yours isnt new model?
I believe the protected Sofirn 21700 is one of the longest ones out there.
ah that would explain it, but why would anyone want a protected in this light?
it is only a few months old and has the “new” clip thats silver instead of black…i read that was one of the ways to tell it was a newer version
i don’t think its protected? it measures 70mm which seems to be normal for unprotected
do u have maybe a 40t or something ? i know in my old e07 that one fits barely but it does, my vapcell 20a doesnt too long… but if the sofirn isnt protected it makes no sense…
not yet, i plan on getting some soon though.
I bought one of the first batch produced. It was pre-Anduril. It had a simpler ramping interface. The one you have sounds like an early version. Could it be these, above, are ‘new old stock’ for sale?
