YuvalS's Hand Made Class, 7th Annual BLF/OL contest entry topic
108 posts / 0 new
YuvalS
YuvalS's picture
Last seen: 8 hours 13 min ago
So I am planning on building a headlamp, hopefully I will finish it by February.
The body will be made of aluminum to double as heat-sink and the battery box will be made of some kind of plastic. both will be build using hand tools.
I want to print my own driver but I have no experience with printing circuits so maybe I will use a commercial driver and modify it.
As a FW I am planing to use my own code that is need some improvements.
Welcome to share your thoughts.
Yuval
EDIT: 29/02/2020
Just before the deadline, I wanted to thanks all BLF members that helped and encouraged me during the build and especially to the annual BLF/OL contest team that pushed me to build the light Smile
I made a short video to summarize the process so people don't have to read the entire thread:
And here is pictures of the final result:
Evanualy, I did used some modified commercial driver and didn't print my own, maybe for the next year competition....
My FW repository
My BLF/OL contest entries: 7th 8th 9th
Edited by: YuvalS on 02/29/2020 - 08:30
sb56637
sb56637's picture
Last seen: 4 hours 14 min ago
Sweet! Really looking forward to it.
CRX
CRX's picture
Last seen: 7 months 6 days ago
Sounds good, always nice to see a self built headlamp Thumbs Up
MRsDNF
MRsDNF's picture
All the best for the build YuvalS. Thumbs Up
YuvalS
YuvalS's picture
MRsDNF wrote:
All the best for the build YuvalS. :THUMBS-UP:
Thanks MRsDN, you too.
So today I made the preliminary sketch of the body.
I am planing to built it using 3 pieces of 6mm Aluminum glued together.
6mm Aluminum is easier to buy and easier to work with using the tools I have.
3*6mm = 18mm will give me enough space for a 17mm driver and 14mm optics + 2 mm mpcp (=16 mm)
My FW repository
pinkpanda3310
pinkpanda3310's picture
Last seen: 6 hours 52 min ago
Nice start Thumbs Up
DBSAR
DBSAR's picture
Last seen: 2 days 2 hours ago
subscribed! Thumbs Up
G0OSE
G0OSE's picture
Last seen: 17 hours 46 min ago
Subscribed! Beer
YuvalS
YuvalS's picture
So my GF travel to Germany for the weekend and I had an opportunity to take over the living room and convert it into a workshop cool
I started to build the body. Since it it made out of 3 pieces of aluminum I decide to first attach the 3 pieces together using screws. It will enable me to precisely drill the 2 mm drills for the screws around body.
I did not manage to use the drill press before the pieces are screwed together so I had to drill another set of drills by hand foot-in-mouth
I tapped M4 to the bottom aluminum piece
And now I screwed all pieces together and can continue working on body but I have to wait for the next time I will be able to conquer the living room wink
My FW repository
grin
Last seen: 3 hours 39 min ago
Good stuff. You may find it easier to tap the holes with a battery drill, it is easier to keep the tap straight. Use WD40 or something similar to lubricate it.
YuvalS
YuvalS's picture
I have lubricant in this green plastic. I also use it for drullind and sawing but never thought of using a WD40, maight be easier to apply, THX
My FW repository
MRsDNF
MRsDNF's picture
You are in so much trouble when your GF reads this thread YuvalS. Love your style. Thumbs Up
CNCman
CNCman's picture
YuvalS Nice build. subscribed Beer
Note: If you do not want oil on your projects, dish soap works just fine.
CRX
CRX's picture
Good start Thumbs Up
pinkpanda3310
Nice room conversion LOL Good to see you make a start Thumbs Up
MtnDon
MtnDon's picture
Last seen: 11 min 49 sec ago
Thumbs Up
YuvalS
YuvalS's picture
After the progress yesterday I wanted to continue working on the body after work. Unfortunately my neighbors are not big fans of me building lights at night (TBH they are also not like it when I build other stuff) cry
luckily, I have found a 220v outlet next to the road around my neighborhood, far from any building and was able to work there
As you can see I have took CNCman advice about using dish soap as a lubricant since it is easier to use when working outdoors
It was quit challenging to drill 12 2mm holes in a 5mm border but I am quite happy with the result, no drill pierced the side of the body and I only broken one drill bit sealed
My FW repository
Kame Sennin
Kame Sennin's picture
Last seen: 1 year 6 months ago
Perfect combo of will and "do with what you have" spirit !
CRX
CRX's picture
YuvalS wrote:
After the progress yesterday I wanted to continue working on the body after work. Unfortunately my neighbors are not big fans of me building lights at night (TBH they are also not like it when I build other stuff) Crying
That’s dedication. Thumbs Up
pinkpanda3310
What they said ^ Thumbs Up
YuvalS
YuvalS's picture
Today I sawed the corners and turned the rectangle octagonal.
Unfortunately I forgot the jigsaw blade at home and the Dremel blade is too small, so I had to use a hand saw.
After sawing, I smoothed it all out using a file. The result is not perfect, but since it all done using only manual tools I am quite satisfied.
The body is finally take shape
My FW repository
CRX
CRX's picture
You’re crazy mate Big Smile Thumbs Up
Couldn’t tell where you were this time Smile
MtnDon
MtnDon's picture
Looks like good work under less than ideal conditions. Thumbs Up
MRsDNF
MRsDNF's picture
Love the new workshop. Beer
YuvalS
YuvalS's picture
Thanks guys, it is the same workshop as previous pictures .
Looks like I will not change this place unless someone will kik me from there.
I am also using this spot to work on my camper car conversion so it is a busy workshop money-mouth
My FW repository
YuvalS
YuvalS's picture
Back to the "Workshop" today for drilling the body using 27mm Holesaw to create some space for the optics and electronics
My FW repository
Agro
Agro's picture
Last seen: 6 hours 4 min ago
Looks nice so far. Smile
raccoon city
raccoon city's picture
Last seen: 35 min 24 sec ago
I cannot see several pics in post #26.
lostheplot
lostheplot's picture
Last seen: 9 months 2 days ago
Looking good,
I once built a Datsun 180b engine in a kitchen in a flat in Melbourne.
sorry all images down
thanks photobucket
MtnDon
MtnDon's picture
Same problem here
MRsDNF
MRsDNF's picture
lostheplot wrote:
Looking good,
Can I tell everyone what else you have done mechanically in houses?
