Sofirn SP36 spewed toxic chemicals throughout my entire house
214 posts / 0 new
Jake257
Last seen: 3 years 2 months ago
So I know this is kind of a weird post, but I’m here just to hopefully get some advice. A couple of weeks ago I bought both the bfl version of the sp36 and the sp36s from Amazon. Yesterday I was in my kitchen. The sp36s was several rooms away and I smelled what I would describe as a mix between spray paint and a new garden hose. I wasn’t sure what it was, but when I went into my office where this thing was charging the smell was extremely strong. I was trying to figure out what it was. I unplugged the flashlight and plugged my phone into the same charger. The flashlight was cold and I was surprised that it still was not finished charging. I soon realized that the smell was coming from the flashlight. in the actual room I would describe the smell as a strong mix between chlorine and a plastic garden hose smell.
I quickly put the flashlight in a ziplock bag and put it in the garage and aired out the room. For the next nine hours I had probably the worst headache I’ve ever had. The smell was so strong that simply plugging my phone into the same charger for 5 minutes has made my phone charging port emit the smell to the point where I can smell it from 3 feet away.
What do you guys think happened and what do you suggest I do to decontaminate things? Obviously I can’t un inhale whatever this terrible flashlight off gassed. I own many Acebeams, Fenixes, Jetbeams and other brands and I have never had a problem like this before. This will definitely be the last sofirn I ever buy.
Edited by: sb56637 on 11/22/2019 - 14:57
Joshk
Joshk's picture
Last seen: 8 months 3 weeks ago
There’s only two things it could be. “Magic smoke” from the electronics, or something from the batteries. I have never smelled a lithium battery, but I think you are describing magic smoke. We have all inhaled a little at some point or another. Just open a window and move to fresh air. And obviously take the flashlight outside.
Bearbreeder
Last seen: 3 years 1 month ago
Pics?
First post?
Amazon return
EasyB
Last seen: 3 months 4 weeks ago
Edit: hopefully it was just magic smoke from the driver/charger components frying, but…
It sounds like one or more of the 18650 cells could have vented, and what you were smelling was the organic electrolyte used in the battery.
This is a serious event that we never like to hear about. Do you have any lingering symptoms?
A cell can vent if it is overcharged or if there is a manufacturing problem with the battery that might cause it to have an internal short circuit.
Now some questions to help figure out what the cause might have been: had you used the light before you charged it and did it work correctly? If so when did you use it? Did you open the light and access the batteries before you plugged in the charger? How long was the light charging before you noticed the smell?
tekwyzrd
tekwyzrd's picture
Last seen: 1 year 1 month ago
Oh, great… I’m waiting for an sp36s to be delivered. Hope it isn’t a problem with the revised charging design.
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws. – Douglas Adams
amishbill
amishbill's picture
Last seen: 2 years 6 months ago
Ruptured lithium batteries smell like the Devil just emitted Hells’ burning version of a Guiness/Egg fart.
I’m curious how this happened.
What batteries did you have in it?
Were they all positive side up?
Did he light ever work?
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
amishbill
amishbill's picture
I was checking the details. Until I see otherwise, I’m going to assume it’s the same driver board as “USB-C 2A” is nothing more than standard USB power run through a USB-C port – just like the other SP36 flavors.
Foghorne
Last seen: 9 months 2 weeks ago
My occupation is an electronics technician and burning components does not cause a 9 hour headache. But lithium will. It is very poisonous and will bring you to your knees if you get a good whiff.
I worked on some devices powered by D size lithium batteries and one day this bonehead at work cut open a unit with a sawzall and cut the battery open too. We opened all doors and evacuated the building for 2 hours until the smell was gone. I never want to smell that again. Serious and very poisonous.
hank
hank's picture
Last seen: 2 days 2 hours ago
Yep. Ask Sofirn how to confirm that Amazon sent you a real product not a fake.
Then assuming it is real, Sofirn ought to arrange for you to send the flashlight head to them for investigation.
That would be a small package.
I’m assuming something failed and overheated in the charging electronics, that it was not a leaky battery.
This is why no one should ever leave a lithium-ion charger operating unattended. Stuff can happen that’s not healthy.
Jake257
Thanks very much for the replies, guys! I was honestly not sure where to go for help with this. to the guy asking for a picture there is really nothing to take a picture of. I haven’t opened the flashlight and I don’t really want to. From the outside it looks normal.
I have had the light for a couple of weeks. Up until this happened it worked flawlessly. I plugged it in before I went to bed. It was still flashing red when I unplugged it which was very odd it should have finished charging after a couple of hours. I had a very severe headache all day yesterday. My girlfriend wasn’t as affected as I was, but she wasn’t smelling around trying to figure out what was going on like I was. I’m not exaggerating when I say as I type this into my phone I can still smell this very strong chlorine sort of smell coming out of the charging port of my phone. My phone is waterproof so I could try rinsing it off. I have cleaned the entire thing with rubbing alcohol but I haven’t poured anything down the port yet. Before I realized how severe this was I plugged my phone into a couple of other USB c cables all of which currently have the smell as well. The room where this happened had my other flashlights, my shoes, my clothes, suitcases all sorts of stuff. I’m not sure that the smell really made it onto everything else. I don’t know if this substance landing on other items and touching them is a problem or if just inhaling it when it was a gas is a problem. Without really understanding what the smell is I’m not sure how serious this situation is or what action I should take. My theory is that since the flashlight is intact and sealed whatever vented vented straight out of the USB port which is why the smell is so strong on my phone and the chargers.
A chlorine smell does not seem to be consistent with what I’ve read about lithium-ion batteries smelling like, so I’m not sure what to make of this. It was a very strong plastic garden hose chlorine smell in the room. The smell that is lingering I would say smells more like chlorine than anything else. Like a chlorinated pool but maybe a little bit different. Not quite something I’ve ever smelled before.
Jake257
Just to add some more details I was using the sofirn cells that were included. The light worked fine before. The batteries were definitely in the correct orientation. The only thing I can think of is I brought the flashlight in on a cold night and there was probably some condensation.
Is a chlorine plastic hose smell really consistent with a lithium ion battery venting? I feel much better today. What should I do here? should I be worried about the rest of the stuff in the room? I also had some vitamin supplements and a few other things although most of them were well sealed.
Jake257
The light was used the day before. I have never opened it a single time since first installing the batteries. I am pretty much certain it was a genuine product because like I said I bought the blf version as well so I have both of them they are identical looking identical feeling and put out an identical amount of light that is exactly the same temperature.
Bearbreeder
Pic of the flashlight as it currently is
Sorry but need to confirm first, also to see if it is a genuine product
Not saying yr story isnt true, but its the times we live in
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 8 hours 28 min ago
It could literally be any thing?
The light, The batteries, The charger itself, Internal wiring, USB cable?
The smell you are describing sounds like a PCB melting, My soldering iron broke and i was doing some work didn’t notice the tip was at like 600 degrees Celsius and i melted a PCB. Worse smell ive ever the cheaper PCBs seems to smell worse than the better ones.
Joshk
Joshk's picture
You really need to open that up and see what’s damaged for sure. You can’t put that in the mail and return it if it has damaged lithium batteries. You need to know. You really need to know. Heck, now we want to know Big Smile
Bearbreeder
https://postimages.org/
Is a quick and fast way to upload pics from ur phone
Just post the link, no need to embed em in the post
amishbill
amishbill's picture
It’s time to find some cheap plastic or latex gloves, go outside and open the light. Dump the batteries and check the positive ends. Look at the face of the driver. Describe and/or take pics of what looks ‘wrong’.
hank
hank's picture
Never. do. that.
Never leave a li-ion charger operating unwatched.
Worst case, NOT applicable to your experience, but for caution to others:
WARNING: if a cell vents with flame, that reaction can produce hydrogen fluoride, which is what you’d want to immediately tell an emergency room doctor as
the health effects of exposure to HF may not show up for several days.
LTC
Last seen: 3 months 9 hours ago
You mentioned : The smell was so strong that simply plugging my phone into the same charger for 5 minutes has made my phone charging port emit the smell to the point where I can smell it from 3 feet away.
Do you even suspect your charger than to the light?
Jake257
Okay guys I am going to work on this. This thing is seriously inside of a plastic bag inside of a tupperware outside because even the plastic bag was not enough to get rid of the smell so I’m not looking forward to it but I guess you’re right. Without taking the pics I’m not giving you enough info. So if I had a severe headache all day yesterday but I feel much better today do you think I’m physically okay at this point? What would an emergency room even do about hydrogen fluoride? From my understanding when you’re exposed to stuff like this there isn’t a whole lot they actually do for you.
Jake257
The entire light smelled like this. I was using a 7-foot USB cable that was probably 5 feet from the charger. The charger has no smell whatsoever. Just the tip of the cable. Whatever offgassed and filled the entire house with a smell was bigger than a USB c connector
Bearbreeder
Pic of the top of the bats (positive), the inside of the head (where the bat + connects to) and the usb port (flap open)
That should tells us what we need to know
Also the negative bat terminal and the springs if u can
A respirator might help
amishbill
amishbill's picture
- do it outside
- If there’s airflow, hold he light downwind of you
- if there’s no breeze, do you have a small fan you can use to blow its smells away from you?
After a few days, there should be very little gas / smoke left in the light, but safety is always a good habit.
bmengineer
bmengineer's picture
Last seen: 1 week 5 days ago
Ziplock bags aren’t scent proof at all, so that’s not surprising. If you can afford to, I would play it safe and ask a doctor.
Find all my reviews of flashlights and more gear at www.bmengineer.com
Jake257
Pictures are coming shortly. Just a couple of very interesting updates. The first one is the light still turns on and functions. The second is the cells look to be intact, but there is clearly burning on the board on the bottom of the head that the positive terminals contact. And the third is the fact that the smell is still exceptionally strong that even with fans blowing outside it was difficult for my girlfriend and I to tolerate. I really can’t understate how strong this smell is.
Jake257
G0OSE
G0OSE's picture
Last seen: 10 hours 57 min ago
Something defo went wrong there then, burn’t up alright – I’ve seen something like this before on here, now who was it?
If memory serves me correct, he went outside at night and it happened in his hand and there was smoke in the head. Was a different light though I think….
fluke
Last seen: 3 days 20 hours ago
One of  my SP36's threw a wobbly  while charging and stank to high heaven of a chemical smell.
It was the charging circuit as far as I could tell.
Jake257
The cells look okay right? Am I just dealing with a very smelly board? I’m assuming it’s the charging board in particular because the flashlight still functions, ramps everything
Jake257
Just out of curiosity when a board burns up and start smoking and smelling what is actually in the air and what is the lingering smell? Is this essentially just burnt plastic, resin and solder and that kind of thing? I don’t really know what these are made of.
Jake257
fluke wrote:
One of  my SP36’s threw a wobbly  while charging and stank to high heaven of a chemical smell.
Sounds like exactly what happened to me. Did you have any physical symptoms? What did you do just throw the light away and throw the cable away?
Topic locked
