Ziplock bags aren’t scent proof at all, so that’s not surprising. If you can afford to, I would play it safe and ask a doctor.
Pictures are coming shortly. Just a couple of very interesting updates. The first one is the light still turns on and functions. The second is the cells look to be intact, but there is clearly burning on the board on the bottom of the head that the positive terminals contact. And the third is the fact that the smell is still exceptionally strong that even with fans blowing outside it was difficult for my girlfriend and I to tolerate. I really can’t understate how strong this smell is.
Something defo went wrong there then, burn’t up alright - I’ve seen something like this before on here, now who was it?
If memory serves me correct, he went outside at night and it happened in his hand and there was smoke in the head. Was a different light though I think….
One of my SP36's threw a wobbly while charging and stank to high heaven of a chemical smell.
It was the charging circuit as far as I could tell.
The cells look okay right? Am I just dealing with a very smelly board? I’m assuming it’s the charging board in particular because the flashlight still functions, ramps everything
Just out of curiosity when a board burns up and start smoking and smelling what is actually in the air and what is the lingering smell? Is this essentially just burnt plastic, resin and solder and that kind of thing? I don’t really know what these are made of.
Sounds like exactly what happened to me. Did you have any physical symptoms? What did you do just throw the light away and throw the cable away?
Do you have a DMM to measure the cells?
Either way i wouldnt use that light, especially the charging
Amazon return
Put it on charge first time, bad stink came out of it, no smoke, still worked, but would not charge.
Stripped out userable bits and binned the rest.
Bought 2 more.
Burnt electronic stuff usually gives out that acrid odour, I think it’s just the burning board - if it were me, I wouldn’t trust any of it batteries or light - return the lot.
Some observations from a quick glance at the pictures you linked:
- The batteries look intact. From your pictures the head of each cell looks completely normal. I think if a battery vented there would have been some visible damage or mark on the wrapper. That said, I’m not an expert on venting batteries, but I suspect that your cells did not vent. That could be good news since it may mean your house isn’t contaminated with lithium ion battery byproducts. Also if a battery had vented, the light might have exploded and burned your house down.
- There is an obvious burn mark on the PCB on the inside of the head. This suggests something on the driver self-destructed. The driver and/or charging circuit is probably destroyed.
My conclusion:
- Defective light probably caused by poor quality control during manufacture on Sofirn’s part.
- There is a remote chance the problem is your USB-C cable. Are you using one from a name-brand manufacturer or that came with the light? or are you using a cheap generic one? However, my guess is the problem isn’t the cable, since if it was I think your light would have malfunctioned the first time you tried the cable in it.
My recommendation:
- Contact your vendor and/or Sofirn to see about getting warranty repair. Also check your manual for warranty information.
- Do not attempt to activate the light since something in it is broken and it is a safety hazard. Do not reload the batteries into the light.
@Jake257
For getting rid of the smell in that room get a pound of freshly ground coffee, put a bead sheet on the floor and spread the coffee on it, leave it for a day it should take care of that nasty smell. When we transport fish on big trucks that is how we get rid of fishy smell.
You can always try fabreze.
If you shake the head, can you hear anything gently rattling? One of my SP36’s had a screw floating free inside of it.
If you try one battery at a time, do they all work?
Yea, the batteries look good to me. I blame the charging circuit. Return that sucker for a full refund.
You seem quite sensitive to the smell… I would research how the professionals clean up a home after smoke damage. Good luck.
What model charger & cable were you using?
There are so many higher voltage (20V) charger systems using USB-C now that I wonder if using the wrong combination of charger and cable could apply more voltage to the light than what it was designed for and fry it.
About how many charge cycles did you put the light through before this problem happened?
(I just ordered 2 of these. One of them will be a gift. Now I’m concerned. Dont want to give someone a poison gas bomb.)
Odds are very slim that the S model has a proper USB-C PD high voltage/current capability. “Real” USB-C PD requires the endpoint device to tell the charger what it wants and/or can accept. I would love to be wrong, but Sofirn has little incentive to rework the firmware AND driver when a simple firmware change will achieve the same effect.
If anyone has an SP36S and a ‘real’ USB-C PD type power supply with a C-C cable, can you test this combination of parts?
Sofirn does include a cable with their devices i believe
