@Jake257
For getting rid of the smell in that room get a pound of freshly ground coffee, put a bead sheet on the floor and spread the coffee on it, leave it for a day it should take care of that nasty smell. When we transport fish on big trucks that is how we get rid of fishy smell.
You can always try fabreze.
Yea, the batteries look good to me. I blame the charging circuit. Return that sucker for a full refund.
You seem quite sensitive to the smell… I would research how the professionals clean up a home after smoke damage. Good luck.
There are so many higher voltage (20V) charger systems using USB-C now that I wonder if using the wrong combination of charger and cable could apply more voltage to the light than what it was designed for and fry it.
Odds are very slim that the S model has a proper USB-C PD high voltage/current capability. “Real” USB-C PD requires the endpoint device to tell the charger what it wants and/or can accept. I would love to be wrong, but Sofirn has little incentive to rework the firmware AND driver when a simple firmware change will achieve the same effect.
If anyone has an SP36S and a ‘real’ USB-C PD type power supply with a C-C cable, can you test this combination of parts?
Trying each individual cell is a good idea. I didn’t think of that. Maybe I will give it a shot before I send this back. So you guys think I’m good to send this back and it won’t pose any safety hazards in the mail?
This is the last time I will buy a cheap light personally. I’m not really a modder or active on the forums, but I have been collecting flashlights since the 90s. My first high power LED light was back around 2006 from novatech. I still have it it still works. I bought my first fenix around 2009. I have a pretty large collection mainly of acebeam and fenix lights and I have never had a problem with any of them.
I would say I charged this light about five times before this happened. I don’t know about the USB cable brand but it’s a good quality cable that has worked fine. The wall unit is LG and I have used it to charge many different things including some of my acebeam and fenix lights.
I only bought this light because it was high CRI and did some things none of the quality brands offered, but from here on out I am done with bottom shelf garbage brands like this. The light did work fine for a few days, but from the moment I open the box it was clear that you get what you pay for. This didn’t particularly bother me but the machining was sharp and the anodizing had several flaws. I’ve always been a function kind of guy, but it seems that the low build quality continued inside of the light. I think good evidence of that is another guy who replied here had the same problem.
Too bad these guys are based in China. I’d make them buy me a new phone or pursue litigation.
Regarding the smell , you could look HERE it’s about burnt food odours, but presumably it would work on any odour.
Either way you may have some cleaning to do.
I’m pretty sure the chlorine smell is halogenated dioxins and furans. Pretty nasty stuff. the light is outside the house has been airing out for a day and a half. The chargers and my phone still have a very strong smell. Not really sure what to do about that. Maybe it will go away. I’m okay with throwing the cables out but I don’t know if I want to replace an $800 phone over this.
So in my original story I explained the phone connection. I know I am a little bit long-winded though. when I first went into the affected room my phone was dying so I immediately unplugged at the flashlight and plugged my phone in not suspecting the flashlight at this point. My phone has a strong smell from being plugged into the same charging cable for a short time. All of the subsequent cables I have used to charge my phone in the last day and a half also now have the smell. I cleaned my phone pretty thoroughly with rubbing alcohol but I don’t know how to clean this out of the port or if it’s even possible. It’s giving off a strong chlorine like odor which I suspect to be halogenated dioxins and furans given off from the burning board.
Yeah my phone works totally fine. It’s not a function problem. But I’m not making this up when I tell you that you can smell like chlorine like smell coming off of the charging port on the phone a day and a half later. Just to make sure I wasn’t insane I had a couple of other people check and they don’t like the smell of it either and they can detect it from several feet away.if someone wants to give these guys a heads up about this and link them to the thread I’m totally fine with that. Hopefully they don’t get it deleted or something because this is a true story that people should know about.
