Introducing Next Generation of the EC35
12 posts / 0 new
ACEBEAM
ACEBEAM's picture
Last seen: 2 days 4 hours ago
The Acebeam EC35 Gen II is the upgraded version of the original EC35. With an improved LED, charging system, and aesthetic, this light translates into a must-have EDC. Powered by a single 18650 battery, the EC35 Gen II utilizes a Samsung LH351D LED to provide a stunning 1100 lumen output. This powerful beam makes it easy to accomplish daily tasks or take with you camping, hiking, or traveling. Featuring a built-in USB-C charging port this Acebeam light can recharge super fast making it easy to get it back into your flashlight rotation and keep it on hand as an every day carry. Don’t have time to charge or have a powered up 18650 on hand? Easy. Replace that battery with two CR123A batteries and you’re all set to go. Constructed with Acebeam quality in mind, the brand new EC35 Gen II is set to impress and dazzle any EDC user.
You could click here and view more details: http://www.acebeam.com/ec35-gen-ii
kanton
So it has less output and less peak intensity than the previous model, got 2mm longer but now has integrated charging via USB-C?
Edit: It also got 2 independent switches now?? That’s GREAT! I would LOVE to see an 18350 version of this, since dimensionwise it’s just too close to the excellent Acebeam T36 for me.
zak.wilson
Last seen: 5 days 21 hours ago
I’ve suggested that manufacturers should use the LH351D instead of the XP-L in lights a number of times, but low-CRI and 6500K like Acebeam is using is not what I had in mind.
Though I did hear a certain dealer should have a batch with the 4000K SST-20 in a couple weeks.
Edit: I just noticed it has the UI from the L30 and friends. I love that UI.
Ceilingbounce – flashlight testing and runtime graphs for Android
kanton
Yeah, I love the UI. I really just wish they had a light with that 2 switch UI in a shorter version.. like 10cm with a 18350. Or swappable mid-segments like the FW3A.
zak.wilson
I just noticed, it’s also a powerbank. That’s it. I need one (the special edition with SST-20, of course).
KevinZA1988
KevinZA1988's picture
Last seen: 2 weeks 3 days ago
Thanks Acebeam, 1 lumen or less moonlight. I must get this one…
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, BLF LT1, Convoy L6, Convoy C8+ , Convoy S3, Emisar D4, Fireflies E07, Jaxman E2L, Manker MC13, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II.
Most of them have been modded! =)
https://photos.app.goo.gl/JaJaDv4V838AEJf39
Anthon
Last seen: 3 weeks 1 day ago
So power indicator light is green until 11%? I think it’s useless, it’s too low, it should be blue o orange from 50 to 11%. Otherwise you can have the cell at 15% and the light will be green like with a fully charged cell
oweban
oweban's picture
Last seen: 3 weeks 5 days ago
This…. this is something I could get behind, but not with a 6500K LH351D. As per zak’s post; hit us up with a good tint bin SST20 4000K, and then we’ll talk.
Mark M
Mark M's picture
Last seen: 47 min ago
It will provide 2 amps to charge your phone. The flashlight seems to charge the 18650 battery at a max of 1 amp. You can have the light on any mode but turbo and it will still charge your device while on.
Ventsi
Last seen: 1 hour 24 min ago
Can you post a picture of the flap? I seriously avoid buying lights with rubber flaps, for this I might make an exception.
dorsal
@ Mark M
What is the name of that electronic device that measures? I may need that.
Thanks,
dorsal
Agro
Agro's picture
Last seen: 1 min 45 sec ago
USB Tester”.
