Interested
Interested dependant on price
Gotta have one!
Interested, Did they say any thing else on the light has changed?
Good question. For that led it definietly need some more cooling fins. Maybe a design like MF02.
But I think they will do the cheap way. Slap in the led and it will heat up superfast and stap down.
This LED won’t be any worse than the XPH50.2 edition?
I’d love to see this light with a flat white.
ZozzV6: everydaysurvivalgear:Interested, Did they say any thing else on the light has changed?
But I think they will do the cheap way. Slap in the led and it will heat up superfast and stap down.This LED won’t be any worse than the XPH50.2 edition?
It depends what you mean by worse. It’ll heat up faster than the XHP50.2 but also have a lot more throw.
Interested
I read somewhere it can draw 28A
Without additional cooling, you’ll get 3 seconds on turbo before your hand combusts
Interested
Interested depending on price and driver + UI.
Interested in the SBT90.2 version
I’m sure it’ll last at least a minute on turbo. More cooling fins dont help turbo runtime much. Thermal mass does. If the smaller and lighter NI40 can handle this LED I’m sure the FT03 will be fine. Only thing is it might take long to cool down once it’s heated up.
Interested.
Interested
interested
Interested
Nah, I will have full 4 seconds thanks to the help of oven mitts. My hands could do even longer but solder melts so fast…
But jokes aside - IIRC my Emisar D4 pulls 18A and I don’t complain about it overheating too fast. This one will be fine.
On a separate topic, I’m fantasizing about having this light with Andruil. Is the charging board on the same PCB as the driver or is it separate?
