Well, I've been really busy again - and I've not had much time to invest in this project.. But I did get some more XM-L's soldered down (4 sets of 3 installed now) and There are no interaction problems. The sets can run quite happily in conjunction with one another. The problem at this point is with taking measurements and looking at signals - it's just SOOO bright in and around the circuit board that I can't even see the components. I finally put some diffusion film that I had laying around over the groups of emitters, and that helps a lot.
Since the rise/fall times of the FET Gates was a problem, I figured you all might be interested in how well the new gate drivers work.
This is a capture of the scope taking measurements of (top) the gate of the fet and (bottom) the output of the DSP / Input of the Gate Driver. These parts work incredibly well.
As can be seen, there is 47.7 nano-seconds of delay from input at the gate-driver to when the gate driver begins driving the gate. Once that happens, these things slam the gate voltage from zero to 5.5V (well above Gate-Turn-On / rdsOn) in a frightening 6 nano-seconds. Incredible. 53.7 Nano-Seconds for the whole turn-on. The turn-off has roughly the same delay, and an even shorter fall of about 4 nano-seconds. Remember that a nano-second is 0.000000001 Seconds. We're talking FAST.
Going well, just slow because of my limited time.. But forward slowly is a hell of a lot better than backward quickly :)
Where in Michigan are you from? I am originally from Michigan, lived there until I graduated from school and moved to NC for a job, I really miss Michigan though to be honest.
Not the Pilot-man, but search ebay for silicone baking sheet. Just make sure it's smooth both sides. (Some have texture on one or both sides.) I found some in go-fast red that was just about 1mm thick. The ebay vendor I used was siliconesupplies, but I'm not sure they ship to the rest of Europe.
I wish that I could share some photos of my lumen maker, but the patrons that commissioned it want to keep it a bit under wraps for now.
It has much in common with your device. It is built around 15,000 lumen/150 watt (30V/5A) Bridgelux LED arrays in independently controlled modules. Each module has it's own AVR based driver/dimmer/thermal manager/fault manager. They talk to each other and a central control via a RS-485 network. Forced air or liquid cooling though... each module is less than 50 cubic inches. Input power is via a dual-redundant failsafe power supply with 2x16P 20Ah A123 LiFePO4 battery backup.
The biggest configuration so far is 180,000 lumens in a 12 module array. There is talk of doing a 540,000 lumen beast. There is currently a limit of 65,535 modules in an array (but that could be changed) so there is capability for a little more expansion.
I have been SWAMPED at work, an out of town quite a bit, so I haven't put one second into my big light.. Too bad, but I can't do fun projects like this one without the income that working generates :)
In the little bit of free-time that I have had, however.. well, ask and ye' shall receive..
I'm an offroader, and just a few days ago, me and a friend were talking about Xml potential vs. available led bars for 4x4 use (which I believe use P7, Xre or Xpg emitters, but none seen so far with Xml), so I showed him the potential of Xml turning off headlights of my Nissan Patrol and driving in the middle of the woods (pitch black) just hanging my DRY out of the window at High setting.
The beam pattern was less than perfect, ok, but lighting road and surrounding was great, and that was with 3 Xml only. Let me say the stock headlights were dim and yellow in comparison. Now let's imagine your 24 Xml bar! Wow!
I'm following your build-up with growing interest, my electronic knowledge is basic so I have no chances to make my own lightbar... Think that my original very rough plan was to try to use two DRY head assembly, making on a lathe some sort of support to thread the heads on, and then experiment with RC model Electronic Speed Control (fet based) to drive the emitters.
As rough as it sounds, I still like the idea of the RC ESC for driving the leds as it would allow dimming from zero to full power at the turn of a knob on the dash. Not sure how to limit max power though...
Would you think a similar dash "linear" control would be available with your lightbar?
I really hope to buy from you one of your superb lightbar in a near future (black anod' for me, thanks!), or at least I'm willing to do that if they are not going to cost a kidney and some more... ;o)
