You can get lens even with f1.2, but it is an overkill usually (and very expensive). You should do a research before you buy, I am saying this because for example with Canons the 50mm f1.8 sucks a bit in terms of performance, so a good value/performer is the f1.4... I have no idea though about the Nikon lenses (not that you have to stick with the same brand).
As for the RAW... what I do is I shoot in both modes (camera takes a jpeg and a raw). Usually outdoors in a sunny day I don't need to play with the raw file. But there are other times that I open the raw file in photoshop and... you just can do magical stuff with it. A RAW file is unprocessed data from the sensor. So you have total control of exposure, white balance, colour etc, AFTER you take the photo... ;)
The Uniquefire 2180 that I bought has 3 modes, but only Hi-Lo-Disco. And because it came with a battery and charger it was $20 more. Given a choice, I think I would rather have the 5 modes so that I'd have a medium mode and just click through the disco modes when I had to go back to hi. But, yes, my first choice would be either a 3 or 5 mode with NO disco, only varying outputs.
Here's an example of how I mounted a 17mm driver to a 26mm (I think) heatsink module. This is the 1.4A Nanjg AMC7135 driver.
It's messy, but works. I had a heck of a time soldering to that brass module! I used pieces of thin copper (cut off an old CPU heatsink) attached to the driver at opposite ends and soldered to the heatsink module. This particular module was filled with pieces of 4 AWG bare copper wire and solder to give the heatsink more mass (Chicago X's idea). I then added Fujik thermal compound between the driver and heatsink. If I could do it for a 26mm hole, you could do it for a 20mm one. probably just solder the edge of the driver to one side and use one piece of copper to bridge the other side (just be careful not to short anything).
-Garry
P.S. This is from my custom 3C Maglite which I should be posting a build post for eventually.
I just got mine today. It really came up in perfect condition. Well lubed, flawlessly working, well centered and throwy. I only had an old 18650 with me. It had an adapter with it and worked perfectly with a 18650. I found this really bright and as throwy as a Jetbeam BC40. Tailstands perfectly.
Thank you very much for the heads up. I'm glad I haven't paid for a Shadow J series.
I am with you on the praise of the Keygos M10. I have two of them, and they perform flawlessly. In addition, they look good too. I am on the verge of getting a 3rd one. I used them on my bicycles. I have a pair of them on the bike I am on today. Also, I have a 18650 light on my helmet. Thinking about replacing it with another Keygos M10.
Just like you, I have been looking at the PRICES of the competing lights. This light is going for $23 with free shipping. IMO, one of the best deals out there in Flashligt Land!!
IMO again, this light is so good, it would still be a good deal at TWICE THE PRICE!!
I think I mentioned this before. They are all the same. I think they might put the "a" on there when they sell it with battery and charger.. Correct me if I am wrong.. But, I only see the specs for one Keygos M10..
As you all have seen in my previous posts, I have 2 Keygos M10s. They have been working perfectly. I have had them for about 2 to 3 weeks. About 2 days ago, I am riding, I have them mounted on my bicycle, and one of them stopped working. Okay, I figured a battery. When I got to work, I put in a fresh battery, still no work. Okay, I take it apart, put it back together, real tight, still no work. I switch tailcaps from the one that is working, still no work.
I take it apart again, check everything that my newbie eyes can check. Again, retighten the light, and it still doesn't work.
