Nice, in that case could you at some point measure an (ballpark) actual output difference? I’d be curious about that.
All P60vn Mules will benefit from LilV custom extra copper hardware.
Quad Mules are much cheaper than LilV and with LEDs near the center there are less output lost. Heat should be much less too.
Quality stuff
P60vn 650.2
Max 11500 LED Lumen
Max 8600L in SLN Twisty Proto Shown
Crazy Bright but of course has hint of purple
COUPON CODE “BlackFriday10” = 10% DISCOUNT OFF ENTIRE STORE, NOVEMBER 28 & 29 ONLY! - HAPPY THANKSGIVING!!!
Will be all SLN assembly for the next several days
The Clear Anodized did not look “polished” although I hand polished them all…At least its a very tough looking even matte look.
Vinh,
These are seriously amazing, so well done. I love the clear very much, and the polish on the raw is amazing. Have you considered marketing to military or first responders? (maybe you already do). Your lights seem to me like a perfect fit with regards to durability, ease of use, and output when compared to some of the current mainstays employed by most agencies.
Hope all is well with you and your family.
Joe
Received the clear anodized and it is a good bit larger and chunkier than I imagined. Looks more like a 26650 light. The matt look is not bad but I like shiny stuff so I prefer a chrome/mirror like finish but that's just me. Feels very solid and substantial in the hand, which I can see why it can sustain so much abuse. The mass should allow this to handle turbo a very good amount of time though I haven't tested that yet. Given the thickness and weight, I doubt a copper version would be feasible.
I took some measurements with the Texas Ace Lumen Sphere calibrated with Maukka lights. Readings taken at 2 seconds from startup:
Highest mode | 5206 lumens | 7583K | DUV -0.0029 | CRI 73.9 | R9 -4.1 | R12 46 | Rg 68 | Rf 97 | |
2nd mode | 1142 lumens | 7373K | DUV -0.002 | CRI 73.6 | R9 -6.5 | R12 45.5 | Rg 68 | Rf 97 | |
lowest mode | 32 lumens | 6592K | DUV 0.002 | CRI 76.8 | R9 -3.1 | R12 45.4 | Rg 73 | Rf 95 |
The P60 pill is a lil vortex with 8x XP-L HI in the outer ring & 4x XP-L HD at the center. Battery was a fully charged 30T. Keep in mind the TA lumen tube measures mules and wide flooders lower than throwers. Actual lumens should be 6k+.
Vinh, I'm wondering if you know where to find a white or clear o-ring to replace the black one between the bezel and glass?
SLN Available Serials
039. Matte Black Anodized
040. Matte Black Anodized
041. Matte Black Anodized
043. Matte Black Anodized
046. Matte Black Anodized
047. Matte Black Anodized
048. Matte Black Anodized
049. Matte Black Anodized
058. Flat Dark Earth +$65
059. Hypershift Blue/Purple + Extra Clear Coat +$85
https://skylumen.com/collections/v54-lights/products/sky-lumen-nguyen-bulletproof-r-3
If you fancy building your own LilV P60 Mule
LilV MCPCB: http://www.mtnelectronics.com/index….roduct_id=1005
LilV Copper Shell: http://www.mtnelectronics.com/index….roduct_id=1004
Hey vinh, might wanna fix your links:
SL 12x 3535 Copper MCPCB
SL "Mega-Mule" P60 Quad Shell
Thankssssssssss
Great looking light and a really creative original idea to make a light with such charistics.
