Virence VS35SP36 MCPCB - cost effective (High CRI) General Lighting solution
87 posts / 0 new
SKV89
Last seen: 13 min 56 sec ago
Oh no, after all that effort, maybe few hundred hours??, and you got nothing from the City?
clemence
clemence's picture
Last seen: 4 months 1 day ago
Only small orders for mining lamps and handshakes Silly . Nothing is wasted, I learnt many things in the process.
[Clemence]
SKV89
Knowledge and experience is priceless! Beer
Well now back to work on the 4×4 and/or 3×3 E21A mcpcb and RRT01 mod Big Smile I think the mcpcb would be popular since it would be a direct swap into so many XHP70.2 lights in existence.
clemence
clemence's picture
:AWRIGHT:
clemence
clemence's picture
UPDATE 190729: Test Result
http://budgetlightforum.com/node/68213
100+ watt LED wattage
[Clemence]
Tldd
Is there any way to have two isolated sets of LED’s on one board? I would like to have adjustible color temperature, so have alternating rows of 5000k LED’s and alternating rows of 3000k LED’s, where all the 5000k can be controlled separately from the 3000k.
clemence
clemence's picture
No by default. But you probably can do it yourself by scraping the masking and make your own wiring path.
[Clemence]
fneuf
fneuf's picture
Last seen: 1 year 1 week ago
Hello clemence !
Any plans to bring such packages (more particularily the Optisolis based ones, as tested bu Maukka) in a complete bulb format (E27 based for instance)?
Rise and Shine my precious...
clemence
clemence's picture
fneuf wrote:
Hello clemence !
Yeah, I’m thinking to make circular DIY kit for light bulb retrofit. But the problem is in choosing universal sizing for the MCPCB. Would you like to participate in the research?
And one more thing: almost all light bulb’s diffuser are glued to the base. Not so easy to open for general public
[Clemence]
fneuf
fneuf's picture
At the moment I can't think of a better dream solution than using R95 Optisolis to light my rooms. It's your fault, since you made me discover Jetµsolis!
So, you bet I'd be glad to help to find a solution to mod/create our own bulbs!
I know we have Bocian here that is creating some nice custom E27 bulbs, based on Citizen LEDs. He might be of help. Maybe by joining each of our BLF's talent we can build together the ultimate bulb.
clemence
clemence's picture
fneuf wrote:
At the moment I can’t think of a better dream solution than using R95 Optisolis to light my rooms. It’s your fault, since you made me discover Jetµsolis!
So, you bet I’d be glad to help to find a solution to mod/create our own bulbs!
I know we have Bocian here that is creating some nice custom E27 bulbs, based on Citizen LEDs. He might be of help. Maybe by joining each of our BLF’s talent we can build together the ultimate bulb.
I like the sounds: Ultimate bulbs. I’ll try to contact Bocian then. ….or any other light bulb manufacturers
Clemence
Bocian
Bocian's picture
clemence wrote:
fneuf wrote:
Hello clemence !
[Clemence]
Because of the nature of things, safety reasons and the manufacturer’s policy, LED bulbs are not intended to be opened and modified. There will be someone who does not know the basics of electrical rules and we have an electric shock and other problems Sad
Bocian
Bocian's picture
Clemence
I wish you luck with this too. The first question will be how many thousands of pieces you want to order in this configuration Big Smile
clemence
clemence's picture
Bocian][quote=clemence wrote:
Clemence
That’s so unfortunate Sad
[Clemence]
Bocian
Bocian's picture
[Clemence]
Clemence. send me PM about what You want to achieve/produce/sell. What materials, shape, mounts, expected power, way of light distribution (diffuser/reflector/TIR), electrical parameters (current, voltage, power) of Your LED module.
clemence
clemence's picture
Bocian wrote:
[Clemence]
Hi Bocian,
Thanks for your response. This is not about me. I personally have an agenda for another project. So, I’m not going to be the person in charge for this one. Optisolis light bulb is indeed something I have in mind since last year. But at this point I can only provide special custom designed MCPCB and Optisolis LED. Since you already have some ready to use product, swapping an LED module should be easy. Your product use 36V Citizen, right? And being a light bulb, no specific optic is required, just an unidirectional diffuser bulb is needed.
In my opinion Fneuf should be person to arrange another BLF project for BLF ultimate light bulb project. He has done some researches deeper than most of us in this topic. Just like many BLF projects before, this could be a great pilot project for another greater ideas.
[Clemence]
Bocian
Bocian's picture
Yes, I use mostly Citizen CitiLED 12s (~36v) 97 CRI. Some sample photos with E27 base:
5W/7,5W/9W, incandescent 75W:
9W, 12W:
18W:
Centrally embedded COB diode is located on the copper plate, but there is no problem to use other LED module (with a properly selected power supply, of course).
maukka
maukka's picture
Last seen: 1 hour 48 min ago
If an Optisolis E27 LED bulb ever comes to fruition, I’m up for at least 20.
Bocian
Bocian's picture
Here is an example of ceiling lighting:
Sorry if I make a mess in Your thread Clemence.
clemence
clemence's picture
No worries Bocian, it’s related. You can PM me the available space for the Optisolis board. Can you make the driver switch modes by tapping the input? Phillips use this method to switch between CW, NW, and WW. This way I can design a multi CCT copper board
[Clemence]
qandeel
Interested in many. Please make it happen guys LOL
 عُمَانْ
staticx57
Last seen: 1 day 54 min ago
120V compatibility please!
fneuf
fneuf's picture
clemence wrote:
Hi Bocian, Thanks for your response. This is not about me. I personally have an agenda for another project. So, I'm not going to be the person in charge for this one. Optisolis light bulb is indeed something I have in mind since last year. But at this point I can only provide special custom designed MCPCB and Optisolis LED. Since you already have some ready to use product, swapping an LED module should be easy. Your product use 36V Citizen, right? And being a light bulb, no specific optic is required, just an unidirectional diffuser bulb is needed. In my opinion Fneuf should be person to arrange another BLF project for BLF ultimate light bulb project. He has done some researches deeper than most of us in this topic. Just like many BLF projects before, this could be a great pilot project for another greater ideas. [Clemence]
I'd be glad to help with my modest abilities. Like seriously I'm not the perfect technical guy for that (I consider myself way less proficient than you guys), but at least I'm motivated and I'm pushing this idea. So I can still help, coordonate, and maybe handle other aspects: like putting a toe in the water and see if we gather some feedbacks of the crowd.
But before reaching that, we need to make it serious. Which competencies do we need, what specs are we targetting, what is the public for that, etc
maukka wrote:
If an Optisolis E27 LED bulb ever comes to fruition, I'm up for at least 20.
qandeel wrote:
Interested in many. Please make it happen guys :))
The thread I initially created around this topic "LED Bulbs - Ultra High CRI - The Honorable Quest" has reached more than 1400 view in less than 3 days. I don't know the average metrics for topics on BLF, so at the moment I don't know if it is a clue of high interest or not. But let's see that.
I propose, not to interefer more with Clemence mPCB current offering, that we all continue this specific discussion in the renamed:
>> "Ultimate LED Bulbs - Ultra High CRI - The Honorable Quest" <<
And keep the discussion here exclusively about clemence mPCBs.
ma tumba
Last seen: 1 week 5 days ago
I would like to make a mule out of this board, but as is it requires a pretty big head. So I wonder if it can be trimmed at all? The intended led config is 36p.
Also I wonder if anyone is aware of a soda can sized flashlight with a tilting head, which can accommodate this board as is? the driver has to be capable of at least 10amps @ 3.7v
clemence
clemence's picture
It can be trimmed down from 46,6mm diagonal to round 33mm.
- Clemence
lumiere
clemence wrote:
Caleb wrote:
Any suggestions for a casing that is weatherproof and can be used for 110V outdoor residential security/area lighting?
Built in dusk to dawn or motion sensor is a plus.
Thanks!
The possibilities are endless. First you can start with the driver. I like Inventronics, Meanwell, and Osram for their sophisticated options, control, and wide range of choices. But there’s a very good off the shelf ready to use (or assembled) with very small form factor very useful for DIY projects:
Nano & Micro driver
There are 100V, 120V, and 230V variants
For IP 6x rated casings you can use thick linear extruded aluminum heatsink and glass or PMMA cover bolted (with sealant) on it.
Below are my old 2016 design for a hotel’s garden lights. The design was 2 watts each (20pcs in total), centrali dimmable, photo sensor activated. All LED modules and the internal wiring permanently potted in clear optical grade silicone to withstand UV radiation. Plastic or PMMA will yellow and degrades in less than 2 years if exposed to sunlight 12 hours a day.
I am looking for a solution to light up a pathway. Have you considered selling your garden design as a kit (heatsink, MCPCB w/LEDs & glass cover) that just needs to be assembled and wired up?
