[1900k edition is in!] WTS: 1900k-5800k 5mm LED 95+ CRI
529 posts / 0 new
rngwn
rngwn's picture
Last seen: 5 min 21 sec ago
Nismo wrote:
Is it possible to get these in 2200-2700K too? I have a lot of LED candles that I want to change out the LEDs on. Could possibly do a group buy if others are interested.
As far as customization goes, 10k would be a minimum, and the binning will be all over the place, and some or even much of these might not be marketable. I find this quite a bit messy for my liking.
djozz
djozz's picture
Last seen: 25 min 39 sec ago
I think that even with grossly inaccurate binning there maybe enough people to get you to 10K. If I buy a 100 and there will be 30 that have a good tint that is fine with me. Unlike smd-leds, the tint of 5mm leds are simple and fast to check by eye with a plain 5 dollar led-tester.
Maybe you can do it the form of an interest list to take out much of your risk. Estimate an approximate price and divide it in lots of 100 or 200, and see how far the list gets you. If you are close enough to 10K you can try to order them.
I like to see those very warm (2200K?) high CRI 5mm leds becoming available and also warm 3mm leds, I could start an interest list for you if you like?
rngwn
rngwn's picture
Well that’s certainly a nice perspective. I probably won’t do this right away, though. You can do the interest list, but I can’t give words on when I would actually do it. Just like how C01 list currently goes
Although, the “messy” scenario I mentioned of is when they do bin the parts and I get some good bins and some bad bins, I will have to somehow sell all of them. In that cases, I will have to deal with several SKUs in the inventory, which is what I think the “messy” part of the ordeal. One thing is for sure, since this is a customized part, the best bins probably won’t come cheap.
Unheard
Unheard's picture
Last seen: 2 hours 37 min ago
2200K would be really something Smile .
Smile, you cannot kill them all.
djozz
djozz's picture
It is fine if it will not happen right away. To fill an interest list takes at a month or more so no hurry. For an interest list to work I do need a price indication and which led(s) we are trying to get.
LowLumen
Last seen: 7 hours 18 min ago
Thank you sooo much for these! I got my order last week of 100 3400K and have slowly been sprinkling the joy of warm HI CRI LED light 10 lumens at a time. Just doing button cell keychain, an old 2AAA medical light.. and such so far. I have a couple 12 and 30 LED projects in the works to use up half the stash already.
….so I just ordered another 100 3400K. Not to hoard them, I just never want to run out! They seem to be finding homes rather quickly just turning craptastic little lights into fantastic.
Nismo
Nismo's picture
Last seen: 1 week 5 days ago
For now I’ve changed some of my LED candles out to the 3400K 5mm LEDs modded with a Rosco Cinegel #3407 orange filter in front. The high CRI really compliments the professional filter, and the color is amazing. I will try to take some comparison shots between original (monochrome orange LED), modded, and modded with filter. I’m currently away from home so I’ll be doing some mods next week.
Current lights:
Emisar D4V2 Dual ch. W1/LH351D 3500K, D4V2 Dual ch. E21A 2000K/4500K, D4V2 SST-20 4000K, D4V2 SST-20 5000K, D4V2 Ti SST-20 2700K, D4V2 Ti SST-20 4000K, D4V2 Ti XPL-Hi V3 1A, D4SV2 SST-20 3000K Noctigon KR1 OSRAM W2 | FireFlies PL47G2 SST-20 4000K, PL47G2 219B 4500K, E07 219B 4500K Lumintop FW1A SST-20 4000K, Tool AA 2.0 219C 4500K | Sofirn C01S SST-20 4000K, Sofirn SC01 SST-20 4000K, SP10S LH351D 5000K, IF25 SST-20 2700K + 6500K, BLF LT1 | ZebraLight SC700d XHP 70.2 5000K Hi-CRI Convoy C8+ SST-40 6500K Acebeam H30 XHP 70.2 5000K |
rngwn
rngwn's picture
new batch of T/N:
calipsoii – LX104000074TH (5× 3400k)
LowLumen – LX104000088TH (2× 3400k)
Scientist – UA121600039TH (1× 5800k)
djozz – UA042104465TH (2× 2300k)
Unheard – UA042104474TH (1× 2300k)
Skuzapo – LX054011240TH (1× 2300k)
id30209 – RR278750245TH (1× 2300k)
Nismo – RR278750254TH (2× 2300k)
khas – RO247700275TH (2× 2300k)
cetary – UA121600073TH (1× 2300k, 1× 3400k)
OtisCampbell – LX104000091TH (1× 2300k, 1× 3400k, 1× 5800k)
*T/N number beginning with ‘U’ is non-trackable online. Contact local post office for status after 1-3 weeks.
SKV89
Last seen: 1 hour 8 min ago
Does anyone know if these will fit in this light?
rngwn
rngwn's picture
That led seems bi-colored. There seems to be two cathode leads.
If that is the case, you might have to deal with the different positioning of the anode lead.
Unheard
Unheard's picture
Hardest part would probably be to make reliable contact to the shell. Othewise it is just plastic work. You’ll probably need epoxy. Brass pin should be soldered.
rngwn
rngwn's picture
Guess what arrived?
@5500k WB
@2800k WB
djozz
djozz's picture
Wonderful and unique, I have never seen 5mm leds in this tint and CRI Smile , I’m in for a batch! (100?)
Unheard
Unheard's picture
Me too.
Nismo
Nismo's picture
I’m also in for 100 of these 2800K 2300K ones! Looks absolutely gorgeous.
Current lights:
rngwn
rngwn's picture
Nismo wrote:
I’m also in for 100 of these 2800K ones! Looks absolutely gorgeous.
This is 2300k though. “2800k” is just the WB setting.
Nismo
Nismo's picture
Oh my bad, I read 2800K trough the glare on the photo. 2300K is even better, then!
Current lights:
Unheard
Unheard's picture
10 of those in series to an AMC7135, done for each tint, controlled by three Arduino PWM pins. A good idea?
I.e., a panel of 30 LEDs with some degree of tint control. That’s my plan. Housing done with my 3D-printer. My desktop is to be illuminated.
rngwn
rngwn's picture
Gotta be careful with the current though. This batch of 2300k LEDs has 0.1v less forward voltage than the other two tints and also (supposedly?) 45 deg angle rather than 60 degs.
djozz
djozz's picture
Will do a quick voltage/output test when my batch arrives, and post about it here.
SKV89
Hope the tint is below the bbl or it will look too yellow at that tint. If so, I’m in.
id30209
id30209's picture
Last seen: 2 hours 32 min ago
In for 1 pack of turbo warm 5mm
WTB Titanium 4sevens 2xAA tube
staticx57
Last seen: 21 hours 17 min ago
In for a pack of the 2300k
rngwn
rngwn's picture
Order paid last night has been shipped Smile
rngwn
rngwn's picture
News: 4000k variant is in the pipeline. This is from a different source than what’s already put on sale. The tint is unknown (and possibly imprecise) and these costs me more than the previous source. I will do some basic tint testing once they arrive. As always, I will give away someone a sample for CRI test.
Agro
Agro's picture
Last seen: 2 hours 58 min ago
Do you have many of that 2300k LEDs? I have one light with 5mm LED on the way. I’d rather not order before I have the light in my hands and see if it’s mod-worthy….But if you have the last pieces I might just bite the bullet.
rngwn
rngwn's picture
Still have about half the stock (~500pcs) left for 2300k.
Agro
Agro's picture
Ok, I’ll wait a bit then Smile
flightless22
flightless22's picture
Last seen: 11 min 31 sec ago
I’m in for 2 pack 2300k if still available.
khas
Last seen: 1 month 1 week ago
Mine arrived in Denmark today, thanks for making these available Thumbs Up
Wife didn’t like the 3400K much, but these 2300K she finds much more “candle like”
Happy wife happy life Wink
