Why are these batteries different?
The Olight battery is technically proprietary and the light has a mechanism to sense that and not allow turbo.
It’s a “safety feature” (that’s a lie, it’s really just an additional money grab from Olight)
Also note, if you have a USB rechargeable Olight it’ll only be able to charge Olight batteries, not the 30Q…
Think I’m with you. So basically Olight have made it so that you need to use their batteries?
I’m okay with that,I just wanted to make sure my 30Q’s were okay.
I have the Sofirn SP36 coming soon so will the Samsungs be okay in that?
How do I put pics on here like that. Is there a guide? I did wonder!
Here: How to Post Images on BLF
Still can’t get it to post the actual picture rather than just a link
You have to follow the guide exactly.
Not worried buddy. Managed to do it via a copy and paste option from Imgur.
It worked so as long as I keep the images small, it shouldn’t be a problem hopefully.
Done, thanks for the info
Thanks for the explanation, CK. That probably explains why the first Olight I got came with a dead proprietary battery.
So what alligator convinced Olight that the “give away the printer, sell expensive ink; give away the gun, sell expensive ammunition” business model was worth respecting??
Wow, that really sucks.
And I just goggled the Olight cell… seems it’s rated at 4A max discharge current. “Safety”, eh?
Sounds like Apple products! :money_mouth_face:
Are you sure that your 30Q is not a “knock-off”?
I ordered 4-Samsung 30Q button top batteries from Neal’s Gadgets( he only sent me 2 and I had to dispute the charges for the missing 2, since he would NEVER respond to my emails.), and the two 30Q’s I did receive, run turbo fine in my S2R Baton II.
My 30Q’s do not have the non-disposable icon on them, they are pink, and the only text they have on them is:
INR 18650-30Q
SAMSUNG SDI
141
Also the text on mine is not a bold black. It is printed in a lighter black, dot matrix print style.
It just doesn't have the power.
My theory is the tail spring resistance. The 30Q is shorter than the Olight battery and perhaps does not fully compress the spring?
No, but when you look at the text on the battery, it says they are sold by 18650.UK.
When you you to the website of 18650.UK (in the UK) you can see three pictures of this battery.
On the other side is printed, as is on all of my 30Q’s (including a dozen 30Q button top’s)
INR18650-30Q
SAMSUNG SDI
136
EDIT: some re-sellers print their own info on the opposite side of the battery (enough space)
Button-Top 30Q are a good choice for the SP36.
It’s a decent seller,I have also seen lots of reviews using these batteries with no issues. I suspect that it’s because it’s shorter so I will get some other 18650’s to compare.
[/quote]
[/quote]
Thank you for answering that for me
These are the batteries I have from Neal’s Gadgets. Neal’s Gadget 30Q’s
They are the only 30Q’s I have ever used/purchased.
If your S2R Baton works in turbo using the original style Olight battery, then I can only assume the 30Q batteries you have, are not providing the required minimum HDC required for turbo mode.
Others with 30Q’s, and an S2R Baton, will have to confirm if theirs work in it or not.
All I know is, I am sitting here, confirming my 30Q’s work in turbo mode, on my S2R Baton II.
I still believe you either have worn out 30Q’s, and they cannot provide the required HDC needed for turbo mode, or you have 30Q knock-offs.
It just doesn’t make sense that your S2R is defective, if it can turbo with the Olight battery.
Or it could be that your flashlight is an S2R Baton, and mine is an S2R Baton II, and 30Q’s work in a Baton II, and not in a standard Baton flashlight.
